#11 |
![]() Join Date: Aug 2014
I thought the secondaries were actually in the injector housings. I am referring to the valves themselves.
Looking for a ZR-1 1985 Yamaha RZ350-NOT STOCK 1971 Yamaha AT1-Middle of a restoration |
#12 |
![]() Join Date: Mar 2007
You can port and leave them in the head.....the 2ndry ports are full sized 35-36MM in the head
#13 |
The secondary throttle plates are in the cylinder head at the IH/Cylinder head interface. As Lee stated, when I port matched to the IH, I only did the primary ports. I did do the head match w the heads on the motor. My garage looked a bit like a a surgical theatre w plastic wrap over the motor and only an opening over the cylinder I was working on. Used pillow foam to block the runners and would vacuum everything before removing that. As a final, I used 6" QTips dipped in Vaseline to clean up any burrs by the valves.
#14 | |
![]() ![]() Join Date: Nov 2007
Engine covered w/ plastic shower curtain. Only the port being worked on exposed (see ball gauge used to check clearance into the head(s). ![]() Oiled, blue shop towels (x2) stuffed into the bottom of the ports to catch debris. ![]()
#15 |
![]() Join Date: Feb 2024
#16 |
Pete and Marc both do porting.
1993 ZR-1 #211 Yellow On Beige Beast #2 1992 ZR-1 #427 Black On Black *Sold* 1985 L98 Blue On Blue *Sold* |
