07-05-2015 | #1 |
Removing transmission fill/drain plugs
I attempted to drain and fill the transmission oil at our local maintenance day, but the fill plug simply would not budge. I soaked them with WD-40 earlier in the week and using brute force with a 17mm hex and breaker bar damaged the female hex portion of the plug. I didn't attempt to force the drain plug since it was obvious the fluid was not going to be changed today.
Any suggestions for removing these plugs when they seem to be seized? Thanks, Scott
WAZOO Member '95 Callaway SNAT 450 Aerobody Coupe - Black/Black '92 Callaway SNAT 400 Convertible - Polo Green/Beige '91 ZR-1 #1231 - Arctic White/Saddle (SOLD) '90 ZR-1 #2547 - Turquoise Metallic/Black '89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black '85 Corvette 454 Coupe - White/Red |
07-05-2015 | #2 |
Re: Removing transmission fill/drain plugs
I've heard the plugs can be a bear to get loose. I shortened the Allen section to get it as close as possible and used a long breaker bar to get mine out. If you can get the car up in the air get a long pipe and a helper and that should do it. Once the plug gets damaged you only have a few more shots before the trans will need to come out do to the damaged Allen socket.
07-05-2015 | #3 |
Surprises me that it's NOT done. You were in very good company. I've removed the hex from the socket and just used a quality box end wrench which allows you to keep the leverage closer to the plug. You can use a "cheater" also with the box wrench.
Not for a ZR-1 but a friend welded a correct hex to an older box wrench for just that purpose on one of his projects. |
07-05-2015 | #4 |
To get more engagement from the hex drive, I ground the end of mine off to eliminate the chamfer on the end, and just lightly de-butted the edges. I too needed a cheater on my wrench.
07-05-2015 | #5 | |
Before you destroy the plug completely or destroy Torx Bolts on the Injector Housing Coolant Manifolds.........try a little heat from an acetylene torch (do not melt the aluminum). On the Injector housing Coolant Manifolds.......apply heat along each bolt location separately (including the unthreaded shank of the bolt as the shank is often corroded inside the coolant manifold) and on the injector housing where the bolt is threaded (Remove each bolt separately before going on to another). On Cam Cover Torx Bolts........you cannot get heat at the proper location but others have had great success with vibration (Impact wrench). I had great success with a chisel which after thinking ........... it was vibration that loosened the Torx Cam Cover Bolts even in my case. This ALL with engine in car. Heat Always Works (HAW) You might take a photo with cell phone of the plug so we can see hex and outside threads for more suggestions Before you do more damage
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-05-2015 at 06:48 PM. |
07-05-2015 | #6 |
Yep even just a hand held propane torch will do the job.
07-06-2015 | #7 |
I might add a trick an old diesel mechanic taught me/apply heat directly to head of plug or bolt/after getting it hot/not cherry red hot/spray water directly on the head quelching it/sometimes it takes a couple cycles of heat/ cool to get it loose//it will easily come out//try it
07-06-2015 | #8 |
I couldnt get mine loose and it rounded the plug out. I tried several ways and I believe they all helped make it easier for how I did get it loose which was a vice grip and a long breaker bar. There were enough threads to allow the vice grip to squeeze and I think squishing the plug possibly helped too.
07-06-2015 | #9 | |
I have used Channel Locks or a pipe wrench also (after a bit of heat) if you do not have vice grips large enough. Transmission Fill/Drain Plug Source TIPS More VW Plugs
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-06-2015 at 06:04 AM. |
07-06-2015 | #10 |
Not much to add here, but I concur with using heat - aka "the blue wrench", works (on other applications) when other methods fail. Also, I have an impact driver which has worked where nothing else has as well. (sometimes a sharp hammer blow does double duty: might break the bond between threads, and for sure relieves some personal emotional stress that might have built up!)
To make sure it is not a problem ever since, I put some "Neverseize" (sp?) on the threads before reinstalling the plugs. Oh, by the way...! It is probably a good idea to remove the FILL plug first to be sure you can get it out before draining the transmission. Just a thought!!
