06-27-2015 | #11 |
Re: Oil in number 6 cyl.
I have not had the plugs out since owning the car.
06-27-2015 | #12 |
So.....there could have been oil sitting in #6 in the Fall of 13 and you did not notice it?
06-27-2015 | #13 |
I guess its possible that i did not notice any oil on the old plug wires. I did just have a look at the old wires...grant it they have been sitting in a canvas bag for 18months. They were not greasy at all.
I saw it on plug wire today. |
06-27-2015 | #14 | ||
You can actually have no oil on tip of plug wire (black insulator) but get oil on a socket. I have just a tiny bit of oil on two plugs on a 1990 but not enough to remove the Cam Covers Engine In Car which can be interesting. And Definitely not enough to remove the engine Because of the angle of the plug you might have a bit of oil on the bottom section of the plug wire or oil around the bottom hex of the plug only. If that be the case it is much easier to just pull the plug wire and using paper towel clean out the oil without removing the plug once in a while. And when/if you ever decide to remove the Cam Covers install New "O" rings then as that is a normal replacement. Quote:
A Side Note......Use just a tad of white grease on the black insulator where it pops into the cam cover near the top (there is a ring at that location on the insulator). Makes it much easier to remove next time.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-27-2015 at 06:52 PM. |
06-27-2015 | #15 |
I was not much on the very tip of the insulator...much more noticeable on the plug and socket.
I will end up taking it to Dasilva Motorsports to get a once over and a cooling system service. I will get them to check that plug after I have driven it. The oil was dirty. It may have been sitting there for some time. I cleaned out as much as i could and dropped a new plug in. I will check it after I run it before I take to Dasilva |
06-27-2015 | #16 |
OK, I'm guessing the oil is on the outside of the plug and any oil on the electrode got there when you pulled the plug out? Probably just the o-ring like everyone thinks.
Not a show stopper, clean out the cavity, clean the old one or put in a new plug and keep an eye on it. Next time look in the hole with a flashlite and mirror if needed and clean it out before removing the plugs to keep the oil and whatever else may be in there from falling into the cylinder. |
06-27-2015 | #17 |
Its always something. Last year it was the clutch slave cylinder right before i left for Carlisle.
Thanks again! Jeff |
06-27-2015 | #18 | |
Not that big of a deal to change them......remove a few items (brake booster, coolant pipes, etc). Be very careful with those torx bolts if you decide to tackle the job yourself. Impact Gun Required as well as two, three, four, of the correct size Torx tools.....lol DYNOMITE has the how to..........I'm confident |
06-28-2015 | #19 |
I just dont have it in me to drive it in the snow....my Mustang on the other hand....
