Old 06-13-2015   #1
Big D
Default LT5 Misfiring at All Speeds
Hi all, my 90 ZR-1 is missing/rough running at all speeds especially when it reaches operating temp. Turning the power key on and off made no difference. I get spark at all plugs but when I pulled the #3 wire the idle didn't change much. Let her cool down and pulled the plug and the plug showed little evidence of firing. Didn't smell much of fuel either. Pulled a couple of others and they looked good. Next step was to check injector resistance and it was as follows: 1:15.3, 2;14.5, 3:5.7, 4:14.7, 5:13.0. 6:17.8, 7:15.1 and 8:17.3. I replaced the #3 plug and still the same. this time I checked the injector resistance when it was still hot and got the following:1:18.2, 2;19.8, 3:8.0, 4:19.8, 5:11.0. 6:20.6, 7:18.8 and 8:20.4. Now I'm thinking maybe a bad injector at #3 and maybe #5. If so, looks like I'll be pulling the plenum for the first time, what fun. Any suggestions would be appreciated
Big D
'90 ZR1
'69 L46/M21
Big D is offline   Reply With Quote
Old 06-13-2015   #2
TomZR1
Default Re: LT5 miss at all speeds
Change your coil packs, I had same problem. I did all the tests, fuel pressure new plugs wires, even thought bad gas.
(01/24/25: Fuel injectors turned out to be Op's problem, not bad ignition coils)
___
TomZR1 is offline   Reply With Quote
Old 06-13-2015   #3
Originally Posted by Big D View Post
Hi all, my 90 ZR1 is missing/rough running at all speeds especially when it reaches operating temp. Big D
'90 ZR1
'69 L46/M21
Welcome to the Forum
Injectors need replacing
Old 06-14-2015   #4
tomcat
tomcat's Avatar
I agree with all the above posts. Take your time, their are folks in Oregon & Washington that can help you.
Manfred E.......
91 #906
tomcat is offline   Reply With Quote
Old 06-14-2015   #5
Jon at FIC can set you up with a new set of stainless injectors and gaskets and seals (Gaskets c/o Jerry's Gaskets, BTW). I use the Accel #150821s (from Summit Racing) with no complaints for 4 years running now.
Note: As for coil packs, I installed fresh coils with GM coil (direct replacement) "while I was in there" too. (When in doubt of what the readings should be, I measured resistance on both the primary and secondary windings, looking for consistency. However, one of the coils measured "open" between output terminals, so I replaced the all. All the readings then were the same across the lot, and the car runs great!) That was 6 years and 20k miles ago w/ no issues with them since.
Old 06-14-2015   #6
Big D
thanks everyone for your inputs. Looks like I will be going under the plenum for the first time. Should be a good time....... Looking forward to getting her running back the way she should.
Old 06-14-2015   #7
Entering under the plenum is a "right of passage" for LT5 owners, it seems.
Might consider R&R'ing the started solenoid high-current contacts; set ya back around $10 or so.
Plug wires?
Vacuum lines, check valves, rubber unions = OK?
Secondary actuators and linkage works OK?
Old 06-17-2015   #8
Big D
Looks like I'm going to go with the injectors from FIC. Can anyone suggest which brand of coils I should go with and where to get them.
thanks again everyone,
Big D
Old 06-17-2015   #9
efnfast
OEM coils. Get them from Jerrys Gaskets.
(01/24/25: Jerry does not sell OEM coils, he sells BorgWarner E51 coils as a 4-Pack - ZBrink)
___
efnfast is online now   Reply With Quote
Old 06-17-2015   #10
Jagdpanzer
Jagdpanzer's Avatar
I like the MSD 8224 DIS coils.
Not that I notice any improved performance, I just like their red color
http://www.msdignition.com/Products/...wer_Style.aspx
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
