Old 04-14-2015   #1
Dmod81
Default Engine Ticking
All - need your help. My engine has developed a tick. I drove it on Sunday - embarrassingly I did hit the rev limiter. There were no issues when I parked it. Today, when I started the car, I heard the tick. Video is here: https://youtu.be/jiUyyVhvMvk
It does increase with engine rpm, although there gets to be a point where I can't hear it due to exhaust noise. The car does seem to shake a bit. Oil is good and oil pressure is good. I attached my timing light to all of the plug wires, and got only very intermittent flashing on cylinder #6. I plugged in my Tech one, and the R Int is 146 with the L Int at 132. BLM is at 133 for both. Also, the O2 voltages were jumping around a lot.
Is the ticking/knocking noise likely the flywheel, and the overall problem likely the coil?
Thanks for all of your help.
Dmod81 is offline   Reply With Quote
Old 04-14-2015   #2
mike100
Default Re: Engine Ticking
put a metal tube (like an old brake line) on a stethoscope or to a rubber hose you can stick in one ear and run it along the exhaust flange and any welds that might be leaking on the exhaust system.
Old 04-15-2015   #3
A little more information would be helpful like, what year car, miles, mods, what side is the tick on, etc.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-15-2015   #4
Dmod81
92, 56000 miles, headers w/ cats/3" exhaust/Haibeck chip. Coils and injectors were replaced (Accels) in about 08, about 7,000 miles ago. I can't hear it very well from the top of the car, but can hear it better from under. Seems louder on the drivers side, but that may just be the garage wall echoing.
I'll also use a stethoscope to see if there is an exhaust leak or if there is any discernable noise under the can cover today.
So is the no light from the timing light on the #6 cylinder not really a smoking gun then? It just seemed weird that it worked on all 7 of the other wires.
Old 04-15-2015   #5
The motor shake would suggest a miss. Which would be consistent with a cylinder not firing as indicated by the timing light. I'd swap the plugs between 4 and 6 and see if that changes at all. Also compare the color of the plugs to see if they look similar. And see what u get using the stethoscope as mike suggested.
Old 04-15-2015   #6
Dmod81
OK, I'll do all of that after work. Thanks
Old 04-15-2015   #7
Dmod81
Here's a picture of the plugs, 6 on top, 4 on bottom. # 6 did smell slightly of fuel. I switched the plugs, still no fire on cylinder 6. Nothing discernable/ conclusive heard with stethoscope.
I'm trying to look at this as an opportunity to port the top end!
Old 04-15-2015   #8
RussMcB
Not a bad idea but make sure you identify your current problem first! :-)
I might have missed this earlier - Do you see a spark arching if you hold the spark plug boot near a grounding plug? That will be a huge clue to point you in the right direction.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 04-15-2015   #9
Dmod81
No, I don't see anything. So possibly either wire or coil. I'm going to replace both, I already have a set of wires and a set of gaskets.
I figured as long as I'm taking off the plenum, I might as well port since I've been wanting to. I'm also thinking about blocking the coolant as well so it will be easier to pull the plenum again.
Old 04-16-2015   #10
Keep in mind that one coil fires 2 plugs so if the coils dead you should have 2 dead plugs.
