12-09-2014 | #1 |
My Billet alt is here and it fits !! pics and input welcome !
I went with DC power. They seem to have an impeccable reputation throughout several forums I browsed and read up reviews on. They were also just as good as a few other vendors replying via email but were the only ones that were promising fitment and seemed like were confident it would fit my zr-1. Its a 180 amp. is much more efficient especially when hot. has high quality bearings and will pump out a ton more amperage at idle, and be much more efficient and handle higher rpms vs stock.
I received the alternator today and bolted it up. It does fit, the pulley lines up etc but there were a few things that we discussed that didn't turn up as planned. First I had asked for black anodizing, and received billet aluminum. May have gotten lost in the multiple emails we exchanged so not too big of a deal as I may take it apart and anodize the front and back casing over the winter. On the other hand I couldn't decide between bare aluminum and black so its not such a bad thing lol. Second the power bolt is on the side. We had discussed it to exit at the rear. This may or may not have been a mistake or intentional but it was located at 10 o clock (if facing the pulley) so the location should work regardless. Thirdly the power connector they included for the oval plug has 2 wires while my plug has 3 wires. I emailed them and am waiting for a reply but I figured I'd ask here as im sure someone would know what to do there? Here are some mockup photos. the top ear seems on the thin side. I may add washers there. the bottom ear included a sleeve and fits almost perfectly. ABout a 1mm gap but my ground wire fits in there perfectly which runs to the battery so I used that there. Fresh in the box ! mocked up in place. Pretty sure the hot wire is in a spot that should work. gap at the outer ear. will shim it up oem plug on the right, provided plug on the left. thoughts? what are our 3 wires for ? Last edited by 5ABI VT; 12-09-2014 at 07:16 PM. |
12-09-2014 | #2 |
Re: My Billet alt is here and it fits !! pics and input welcome !
Very frustrating. I purchased a chrome power master alternator from Summit. Shown to fit the ZR1.......wrong. It has been awhile sense I have done any extensive part replacement type projects. Too bad there isn't more that can be done to stop manufactures from making false statements regarding their products.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
12-10-2014 | #3 |
Well I like it but could or would they just simply completely redone a factory alternator to avoid all these issues. Seems to be close but no cigar. I do like the aggressive finning although. If they just could have mated the aggressive front end with a stock backend... Or maybe they still can with the correct black annodizing you wanted?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 12-10-2014 at 07:23 AM. |
12-10-2014 | #4 |
These alternators are completely different than stock. They are a call denso hairpin models with a billet front casing to basically retrofit these newer alternators into older cars. From what I've read, the small hairpins basically blow away the factory alternators in every way possible. So using a factory rear is just out of the question really there wouldn't be anything to gain except a billet casing.
So far, the only thing they've gotten wrong is the ear thickness on the outer mount. I'll measure this and send it back to them just in case anyone does order in the future but 1-2 washers will easily make everything snug in there. Besides that I'm not too big of a fan of the spikey fun look and I can easily have it powdercoated or anodized when I want. As for the side post vs rear post, they haven't replied just yet but every denso alt i can google has a side post so maybe it wasn't possible ? Not sure yet there. The only thing in confused about is the wiring. Anyone know off hand what the 3 factory wires in the harness are for ? |
12-10-2014 | #5 |
Make sense, I actually like the side mounted battery mount. The mount at the rear sucks. Ive packed away my electrical suppliment since Im moving maybe somebody will chime in. I love the billet personally, love the buzzsaw look and im surprised Cliff isnt all over this.... Yet
12-10-2014 | #6 | ||
Have not bought one ........yeeeeeeeeet... But thinking
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 12-10-2014 at 12:00 PM. |
12-10-2014 | #7 |
here is the wiring of the Alternator.. better to show an image than explain it
Sorry this was a quick picture taken late with my phone: looking at the OEM connector in your picture there are 3 wires on terminals S,F & L S = RED = direct from Fusible link @ battery F = (VIN J is BRN, VIN 8 PNK/BLK) Comes form Hot in RUN L = BRN, this is for the Battery light on the Dash.. There are 3 pins on the Alt side of the new connector, you will need to confirm which is which with them.. Not knowing the module model and exact pin configuration, You will use all 3 pins S = Sense L = Lamp F = Ignition (I think) as I don't believe ours feed into the ECM
12-10-2014 | #8 |
Oh yeah what was the cost for this Alt? your last post just had a range for cost
12-10-2014 | #9 |
Yep unpinning the connectors should not be an issue with the pack tools however I dont not know what goes where as we dont know what the alt uses for what. They will need to let you know that as well. When you figure it out and get the plenum back in place please follow up and let us know. GC
12-10-2014 | #10 |
Thanks for the replies .. Have a few things to do and then I'm going to have some time to look into the wiring and answer all the questions as best I can. Wiring isn't my forte I have to admit I'm pretty clueless at first glance at what I'm looking at. I do have a FSM I was looking for stereo diagrams and couldn't find anything .. I'm guessing that the charging system would be though.
Total cost was $443 usd for the alt. They offer several colors and anodizing too. One thing I learned about doing the wiring upgrade is that making better battery or grounds isn't just for stereos etc. Like modifying the other parts of a car to make them better.. The electrical system from the factory can be much improved apon. Dimming lights, faster power windows, better battery life. Better grounds and amperage keeps the ignition system happy too which really convinced me to go this route. This amp puts out at idle what the stock cs144 will do maximum, and won't even match it when it's hot. Really happy to hear the side post is favorable. They did put it in the best and only spot I think possible (assuming the case can rotate in 4 positions). To try and answer what I asked for, I sent tons of photos and measurements as best I could to them. Ear to ear seems to be the only one that was important and seems the only thing off is slight thickness of the outer ear. I'm sure for future orders they can make the adjustment . I'll be measuring the gap and post it here as well as email dc about it. |
