11-21-2014 | #1 |
Brighter Aftermarket Headlamps
We all know the stock headlamps in ZR-1s–all C4s for that matter–majorly suck. If that bothers you and you want to do something about it, I have two sets of aftermarket, quartz-halogen headlamps for sale.
Both use H4-type, "high/low beam," quartz-halogen bulbs. Both sets have metal reflectors and glass lenses. One set are E1-coded lamps made by Hella in Germany and have 80/55-watt bulbs. The other set are E2-coded lamps made by the French company, Cibie and have 130/100-watt bulbs Both sets come with light bulb dust boots. Both sets are bolt-ins, that is: you take out your stock glass or plastic, sealed-beams and put in the aftermarket lamps. You may need to re-aim the headlamps to your satisfaction. Either of these aftermarket headlamp sets will give you better lighting during night driving. 40-bucks plus shipping for the Hellas. 50-bucks plus shipping for the Cibies. Email me at fin speed@netmotive.net if you are interested.
11-21-2014 | #2 |
Re: Brighter Aftermarket Headlamps
I'll take the Hellas. email to follow.
Glenn
11-21-2014 | #3 |
SOLD!
Glenn got the Hellas. The Cibies are still for sale...50 bucks plus shipping.
Hib Halverson Technical Writer former owner 95 VIN 0140 current owner 19 VIN 1878 Last edited by Hib Halverson; 11-24-2014 at 01:22 AM. |
11-21-2014 | #4 |
I will take the other set.
Have emailed you Nelson007
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
11-21-2014 | #5 |
Hib,
What headlamps are you running now?
11-24-2014 | #6 |
SOLD!
Nelson gets the Cibies
11-24-2014 | #7 |
I'd like to know too
1990 ZR-1 #2180 Red/Black Many of the usual mods for 460HP, tuned by Marc Haibeck ZR-1 Net Registry Member #1548 |
11-24-2014 | #8 |
When I first got WARP TEN and had Marc do a lot of maintenance and improvement items, we discovered that one of my headlights was cracked. So he replaced the old stock H2 65/60 watt OEM headlights with Hella H4 85/80 watt off-road units. Also re-aimed the lights. Definitely improved visibility and not a problem for oncoming drivers despite the off-road designation.--Bob
11-26-2014 | #9 |
I put a set of Cibie H4's on my full-size Bronco and it was almost the best mod I did to that truck. They were flat freaking amazing, and the cut-off for low beams was perfect. I liked them so much I moved them to my new (same era) f350.
You guys are going to like these, but I'm a cautious guy so I made sure to put them on high for 10 minutes then check the wiring temp. Come to think of it I didn't do that on the new truck - yet. Cheers, - Jeff
11-27-2014 | #10 |
Instead of watching the wiring temperature, I check the current draw with an EXTECH MA220 clip-on DC ammeter. (The handiest tool for tracing electrical gremlins too.) Knowing the wire size, I know the maximum safe current the wire can handle.
QED
