![]() Join Date: Aug 2012
Thanks to Jim Voter for taking the time to install the daytime running lights module. The parking lights and amber side markers light up on the high/bright filaments. In the past, if I had the parking lights on it was on the low filaments and the tail lights were on.
![]() Join Date: Oct 2004
I'm guessing you didn't activate the rest of the actual DRL function. Correct?
In your vicinity I believe there are stretches of highway that require "lights on" even for daytime travel. I wouldn't think this would pass the test. Do they? |
![]() Join Date: Sep 2012
Hey Charlie,
Did you have Jim install them for our fall run at the drag strip, that way I will be able to see you when pull away. LOL Nelson007 =dredgeguy;213869]Thanks to Jim Voter for taking the time to install the daytime running lights module. The parking lights and amber side markers light up on the high/bright filaments. In the past, if I had the parking lights on it was on the low filaments and the tail lights were on.[/QUOTE]
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
The DRL module activates the yellow turn signals in front and the yellow side markers. Doubt this would qualify for true "lights on". If needed, I would just turn on my parking lights with fog lights activated.
Nelson, missed you but understand you were running around Hersey with a sign around your neck looking for 1930 car pieces...............
![]() Join Date: May 2007
I am glad that you are happy with the mod.
The module/kit was well made and well documented. The installation was as easy as any wiring job that involves opening wire bundles ever is. NOTE: The installation requires cutting wires to the front park/turn lights. The kit comes with wire nuts to make connections. Charlie and I decided to solder the connections after we used the wire nuts to verify the set up. For anyone interested in always on running lights, here is a link to Web Electric Products: http://www.webelectricproducts.com/products.htm Just look for Charlie's beautiful 1992 ZR-1. It is the display model for the product. Jim
If it isn't fun, you aren't doing it right! 1990 Black ZR-1 - sold 1993 Quasar Blue ZR-1 1994 Competition Yellow ZR-1 1995 Dark Purple ZR-1 Maryland State Coordinator WAZOO Member |
I read the instructions for the install and the questions I had regarding what they call "synchronization" answered my questions. It's certainly an inexpensive add. Interesting
I couldn't link the instructions but there's a link to "instructions" in the left column from Jim's link to the product. Last edited by WVZR-1; 10-13-2014 at 11:20 AM. |
![]() ![]() ![]() Join Date: May 2007
I've been running this mod for 6 years now. It's a great safety mod and very affordable
