Old 06-05-2014   #1
KILLSHOTS
Default Secondaries? Pros and cons?
Hey guys,
As I understand it, the main argument for KEEPING the secondaries is originality, whereas the main argument for REMOVING them is simplicity. Is that really it? Is there anything I'm missing here? Some other compelling reasons that I should consider one option over the other?
I'm not trying to start a poll of who has removed them and who has kept them, and I'm not really looking for opinions, e.g. "I removed mine and like it, so you should, too!" Rather, I'm just trying to fully understand the pros and cons of both options before moving forward. FWIW, my car is not heavily modified but it's certainly no NCRS candidate, either, so that's not a consideration for me.
Thanks for your input!
Old 06-05-2014   #2
Blue Flame Restorations
Default Re: Secondaries? Pros and cons?
For me, removing them was a no brainer. Less moving parts and less chance for a vac leak.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 06-05-2014   #3
KILLSHOTS
Yeah, that's sort of how I see it too, Brett. But is there any advantage to keeping them, aside from just retaining the car's original complexity?
Old 06-05-2014   #4
USAZR1
USAZR1's Avatar
And those less moving parts that can fall into the intake tract,causing major damage.
First time our LT5's plenum comes off,the secondaries will be history on our car.
USAZR1 is offline   Reply With Quote
Old 06-05-2014   #5
There are no cons
Old 06-05-2014   #6
Fully Vetted
Fully Vetted's Avatar
The only con is it's not original and that's only a con if you want to keep it original. If that doesn't matter to you there is no reason to keep them.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 06-05-2014   #7
Karl
Karl's Avatar
Do all 16 injectors run all the time with the secondaries removed? Or am I way off and the 16 injectors run all the time regardless?
Old 06-05-2014   #8
KILLSHOTS
So far, this is pretty much the feedback I was expecting.
Please forgive my ignorance on the specifics of the system, but am I correct in assuming that removing them will disable the "valet key" function of my car? Remember, mine is a 1990 and the switch on my car functions somewhat differently than '91-'95 cars...not sure if that matters at all.
Thanks again, all!
Old 06-05-2014   #9
PhillipsLT5
PhillipsLT5's Avatar
I agree, mine are gone + 10 HP RWHP with tune, GC lost a motor with them, Marc can burn chip as needed
Old 06-05-2014   #10
Thanks again, all!
16 injectors operate unless motor goes idle. The advantage is that it keeps injectors operational and secondary valves cleaner.
