Old 04-25-2014   #1
Schrade
Default AIR delete... Who's pulled it? Effect?
What do you know about AIR system deletion?
Is it only for emissions? Or for tune? Is it in Calibration at all?
What effect has removal from tune? The OBX hardware I got has only a P side port for AIR plumbing, and I'm considering system delete here...
Old 04-25-2014   #2
mike100
Default Re: AIR delete... Who's pulled it? Effect?
That port on the pass. side is the EGR tube and the early 375 hp engines don't use that. just thread in a bolt and tack weld it closed.
You can unplug or remove the air injection pump and the car will never know- it does not monitor that and there is no fault code to set the check engine light. OBD1 for-the-win.
Old 04-25-2014   #3
Removed all air systems no issues with passing here, or maybe they don't know what to look for. I believe the AIR only runs at start up. In Ga. all they care about is if the OBD1 cars pass the sniffer on the rollers and still have visible cats.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 04-25-2014   #4
4-cam
We have to pass a visual check in colorado. Thats why I added them to my headers. They dont have to work, they just have to be there. Another stupid emmisions rule that does not make any sense. If it wasn't required , I sure wouldn't have gone thru the trouble installing them. Each state emmsion s laws vary .
[I]4-cam[/I]
[I]1991 ZR-1 Blk/Gry #31[/I]
[I]SW Headers/Xpipe- Dynomax Muffs[/I]
[I]Ported top end[/I]
[I]Secondaries Removed[/I]
Tune by Dominic
4-cam is offline   Reply With Quote
Old 04-26-2014   #5
LantanaTX
Mine is not functional and didn't get caught in inspection. I think they just did a sniff test here in Texas.
[SIGPIC][/SIGPIC]1991 #0663
LantanaTX is offline   Reply With Quote
Old 04-26-2014   #6
Schrade
What exactly is the 'Air injection' function? FSM is still snow [dust] bound...
And there's no feedback for the cal / tune?
Looks like header completion just bumped up a day???
Old 04-26-2014   #7
4-cam
The pump adds air to the exhaust on a cold start. Cleaner burn and lights off the cats faster is what im told. Only operates for a few minutes at startup. No feedback so no code when you remove it
[I]4-cam[/I]
Tune by Dominic
Old 04-27-2014   #8
4-Cam is right. It only operates on a cold start (according to Marc H about 90 seconds). We don't need emissions testing in Illinois so I pulled mine and there is no adverse effect on performance. I also don't have cats or secondaries. --Bob
Old 04-27-2014   #9
What do you know about AIR system deletion? I have deleted two.
Is it only for emissions? Yes and then only for cold starts
Or for tune? Is it in Calibration at all? No
What effect has removal from tune? Nothing
See Item #5 LT5 Eliminated Systems
5. Eliminating Air Injection system.
The Air Injection System including the Air Pump has been eliminated (especially for those who are installing Headers). Associated with the Air Injection system is one vacuum line on the drivers side fender skirt above the shock tower. I eliminated the "T" and just moved the "Y" in front of "T" about 3 inches and plugged the "Y" back in where the "T" was. This modification maintains the Cruise Control Vacuum and the associated Vacuum to the Cruise Control Vacuum Reservoir under the Drivers Side Headlight.
Old 04-27-2014   #10
scottfab
scottfab's Avatar
Mine is functional and intact. One of the more easily fixed systems on the car. I have not pulled it.
Scott
