![]() Join Date: Jan 2009
Finally got around to replacing the upper control arm bushings.
I did the lower ones about 3 yrs ago but wanted to wait on the uppers to minimize the complexity of finding any squeaks. (the replacements are polyurethane) No real issue to speak of. Took 4hrs. Time to go out and test drive it in a few hours. I used Energy Suspension for the replacements.
Amazing difference in tightness.
Worth it for sure. The old rubber bushings were soft like sponge rubber. Now for new shoes for her and an alignment. Then I'll be ready for the driving season.
Did that last winter along w new ball joints, upper and lower. This winter, replaced sway bar ends, tie rod ends F/R, and rear trailing control arm bushings. Much tighter steering, perceptibly flatter cornering. I actually can step down the FX-3 setting.
I checked ball joints. Very tight still and coming up on 100Kmi.
By going after one thing at a time I hope to isolate on what needs attention and what doesn't. Next is sway bar but looks fine and the tension can be adjusted. Hubs are good and tie rod ends are good. I may replace the center caps on the wheels though.
Scott,
My ZR has 125k+ so I follow the "while you're there" rule.
#6 | |
It goes back to Engineering 101 at UNL 43 yrs ago. The best solution is the most cost effective one. Not that I haven't shotgunned solutions in the past (bulk replace) but when you have the time and inclination to go for what has actually failed, why not? ![]() I think because mine is not exposed to moisture AND pot holes......... the ball joints are still tight/stiff in the sockets. I was a bit surprised at the rubber bushing though as soft as they were. Can't wait for new shoes on the car. New rubber is the best!!!!
Not a question of shot gunning solutions. I just don't want to take it apart again.
So I multi-task.
I hear that. Not an issue. You just have to know what your goal is.
![]() ![]() Join Date: Feb 2010
Nice write-up, Scott.
#10 |
