![]() Join Date: May 2007
I am on the road in New Mexico and have had the second instance of no A/C operation. In the first case, two days ago, the A/C Programmer seemed to hang-up. It would not change modes, would not respond to Temp up or down commands, and the blower was not running. The next morning, everything worked properly.
Today, blower stopped moving air with all functions of the A/C Programmer working properly. After several hours of no A/C, the blower started and worked properly for the rest of the day's drive. I suspect that the blower motor is failing. I didn't get a chance to "tap" on the blower while it was not running. Sometimes that will start a sluggish motor. Anybody have any other suggestions I can try? Does any one have a spare Blower Motor that I can buy and get you to ship it to one of my planned stops in the next few days. Please PM of email me if you can help. jim@gizmosart.com Thanks, Jim |
![]() Join Date: Nov 2011
If you need one I can pick one up and meet up with you when you are in the national parks in Utah. I am just a couple of hours north. I can load up my truck with tools and any parts that you might need. My work schedule is flexible and I would love to help.
Chris |
![]() Join Date: Jul 2007
Going by what you are saying, I would not be too sure it is the blower motor..
If the blower motor is hanging, why would the unit lock up and and not respond? Have you pulled AC codes? While the Blower motor is probably the easiest fix, I am thinking it could be the programmer itself, remember it is on the fire wall and gets quite warm where it is. I do know the older C4s would have issues with the programmer failing. just something to think about (in case the motor does not work) I might have a used motor, but I will need to look for it tomorrow evening when I get home
I also have a Tech1 I can bring.
I am getting underway early this morn. Thanks for your suggestions and comments. It might be the programmer, but I was able to clear the hang up by pushing the selector buttons from the defroster to the power button in sequence. After it cleared, the blower still didn't start until the following morning.
If I am still having problems by the time I get to Utah, I will definitely ask for your help. Jim |
![]() Join Date: Apr 2004
When my AC programmer buttons started acting up I removed the programmer from the dash took the face off and cleaned the circuit board were the small button nubs make contact. I cleaned with a pencil eraser. Worked great after that.
![]() Join Date: Aug 2006
Jim,
If you need a cannibalized part let me know. I'll run up, remove and figure out a way to get it to you. One simple part to consider is the fan resistor on top of the condenser housing. |
#8 | |
![]() Join Date: Apr 2007
![]() Join Date: Dec 2003
If the refrigerant is low, the coil will ice up and prevent air blowing through the coil until it thaws out. I had this problem in the 95. You can thaw it quicker, albiet a bit uncomfortable, by running the heater to "defrost" the coil. When you said after stopping overnight, it worked fine the next morning, it rang a bell. So, if it stops blowing, turn the AC off for awhile & just run the fan & see if that helps until you can check the refrigerant.
BTW Jim, I didn't read this thread until last night. Gosh, I wish I had read it sooner. We could have gotten together & shown you my LT5 parts stash & had some lunch when you came through OKC. By the time I read it, you were in Amarillo. I sure am sorry I didn't read it sooner. Never imagined you would be departing right away.
#10 |
![]() Join Date: Mar 2006
Had the same issue with my 92 conv. I did replace the blower motor but had intermediate "no blower operation". Turned out I had a bad connection at the 4 way connector under the hood. The next time it quits wiggle this connector under the hood.
Jon R. Member #490 1992 ZR-1 Arctic White/Red 2008 Z51 Silver 6 spd (Daily driver) ![]() |
