11-11-2013 | #1 |
Pulleys
Hi Guys
I will be ordering aluminum pulleys Power Steering, Water Pump. Colors are Black,Blue,Red,Silver. These are half the weight of stock steel pieces. $199 each + shipping I can do checks or paypal add $6 Please post I would prefer email: petezr1@gmail.com PS pulley/WP pulley or both and color. Thanks Pete
11-11-2013 | #2 |
Re: Pulleys
Stock sizes? OR?
11-11-2013 | #3 |
Re: Pulleys
Have both of these and yes there are very light. In black, can't tell them from stock.
11-11-2013 | #4 |
Re: Pulleys
Just curious, what benefit are the lighter pulleys?
11-11-2013 | #5 |
Re: Pulleys
Lower rotational inertia in addition to less weight.
11-11-2013 | #6 |
Re: Pulleys
11-11-2013 | #7 |
Re: Pulleys
11-11-2013 | #8 |
Calculations
Zero additional hp. Just like a lightweight flywheel.....a light weight flywheel and/or lightweight pulleys driven by the harmonic balancer allows quicker engine acceleration which in turn allows you to get to a higher engine hp output quicker.
In other words......you reach 7,000 engine rpm quicker which multiplied by torque is Horsepower. Omega X T where Omega is Radians per second and T is torque in ft lbs...... 550 ft-lbs/sec is one horsepower. Take a look at L98 Frisbee Horsepower below Tech Info - LT5 Horsepower and Torque Calculations Tech Info - ZR1 Differential Gearing and Vehicle Speed Calculations Tech Info - ZR1 Wind Force, Rolling Resistance, Drivetrain Loss Calculations Tech Info - LT5 Camshaft Timing Calculations Tech Info - LT5 Pressure Drop In Oil Lines Calculations Tech Info - LT5 RC SL4-205 injectors (500+ hp) Calculations Tech Info - L98 Frisbee Horsepower Tech Info - LT5 Coolant Flow Calculations
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 11-11-2013 at 11:58 PM. |
11-12-2013 | #9 |
Re: Pulleys
So if F=ma, w A being increased, then you have a greater force but you've also reduced the mass. A wash?
11-12-2013 | #10 | |
Re: Pulleys
a=F/m where a is vehicle acceleration and m is mass of ZR1. F = Wheel Torque divided by wheel rolling radius. F increases with engine rpm and increases faster if engine rpm increases faster by reducing pulley inertia. m decreases by reduced pulley weight albeit such a small percentage as to be Negligible. Keep in mind these pulleys have the largest part of their inertial resistance......The fluids they are pumping such as water and power steering fluid. All that being said true meticulous, fastidious, picky perfectionists like some of us install these pulleys on all their Zs (me included) Pete is offering aluminum pulley colors (Colors are Black,Blue,Red,Silver) not offered anywhere else. I am assuming these are Powder Coated or better yet (anodized) colors. Last edited by Dynomite; 11-12-2013 at 11:12 AM. |
