Old 10-09-2013   #1
taximan
Default Rear hatch weatherstripping
Anyone have any suggestions on finding replacement hatch weather stripping GM part # 09768068.
Coming up empty from the General, and even GM parts direct is out.
1965 Corvette Black/red Vert
1995 "Last" Admiral Blue ZR1 #438
Member # 760
NCM Lifetime member #1005
NCRS # 23110
[I][B]Sting Rays Corvette Club of Florida
Gold Coast Corvettes Club[/B][/I]
taximan is offline   Reply With Quote
Old 10-09-2013   #2
efnfast
Default Re: Rear hatch weatherstripping
www.corvette-rubber.com. Drop the registry name.
Old 10-09-2013   #3
I'm going to be in the market in a matter of days now too. I'm looking at Willcox (CF forum sponsor) and some guidance/suggestions from anyone here that has some input on weather stripping in general.
I'll keep ya posted. U do the same!
P.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-09-2013   #4
efnfast
Robert, (cvette98pacecar) set us up with corvette rubber. I have not bought anything from the yet.
Old 10-09-2013   #5
Schrade
I did it once a few years ago with a piece from Mike's (or Eckler's; don't remember). It was before Gore invented the web, so I didn't photo-doc it to the forum boards...
THought it was a straightforward job. Cleanup of old adhesive was a bear. And the new rubber is short - I think that's why 2 vettes that I've bought had it cut in the corners. It will swell substantially with a LIBERAL wipedown of Trans-X on a cloth rag.
With the right solvent for old adhesive cleanup (sorry - can't remember that either), and if the assembler used enough of it, it will take off the top film, and leave plenty fresh OEM adhesive exposed to re-install... Don't touch it then - it's STICKY stuff.
I unbolted one strut, got behind it, re-bolted, then got it behind the other strut.
Old 10-09-2013   #6
http://www.youtube.com/watch?v=vUI71JB3HJk
Also in this thread I have several comments on the job.
http://forums.corvetteforum.com/c4-g...therstrip.html
Old 10-09-2013   #7
Meanmyz
Meanmyz's Avatar
I bought the rear hatch strip from GM Parts direct a little over a year ago. In hearing that they are out, it brings up the question...
If GM doesn't have any, will they be making more? Will GM still support the C4 for weatherstripping?
Meanmyz is offline   Reply With Quote
Old 10-09-2013   #8
From my point that would be no big deal IMHO the original GM hatch seal was designed to fail. Always at the corners. At least Wilcox tries to address this issue with corner reinforcement.
Old 10-09-2013   #9
Schrade
Looks like the tech's turbo coffee spooled up @ about 3:38
MAMO had the part right about some adhesive remaining, if you cleanup with alcohol-based solvent. Couldn't remember what solvent I had used...
First however, maybe clean the dusty jam with soap and water sponge - this won't solve the old adhesive yet. Otherwise, the dusty jam and debris will wipe INTO the fresh exposed adhesive, as it solves with the alcohol wipedown next. And you can cut the rubbing alcohol to about 2:1 alcohol / water. This is all the strength needed to solve the top layer of old adhesive, and leave fresh adhesive, like MAMO was showing...
And maybe instead of silicone GREASE, use silicone spray (Armor-ALL, or similar, with silicone). I think even if you wipedown the grease to a fine film, it still holds new corner jam...
My .02
Of course, like backsides and how you wipe them (front-to-rear, rear-to-front, sideways, spin, blot, swirlie, paperless etc.), everybody's got one, and does it different
Old 10-09-2013   #10
vinsZR-1
vinsZR-1's Avatar
Just purchased one from Charles Clark Chevy in Texas 288.00
Vince #1966
vinsZR-1
vinsZR-1 is offline   Reply With Quote
