03-29-2007 | #11 |
Re: Canadian delivery
Daytime Running Lights - the lights automatically switch on when you start the car as a safety feature
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
03-30-2007 | #12 | |
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
03-30-2007 | #13 |
i think its actually the fog lamps that act as running lights...i want to get rid of the lights flipping on every time i encounter some shadow with the car...can you check the resistor value ?
thanks bj |
03-30-2007 | #14 |
check my earlier post.
what the DRL lights are, is the signal/park lights. the signal is brighter than the park function. the DRL is the bright side of the bulb (signal) on continuously except when using the signal function. that's not really a big deal. it's the headlight's popping up like when a cloud goes over. as you stated very,very annoying. but no, it doesn't have anything to do with the fog lights.
