Old 05-17-2013   #1
Default Dash Pad swap..
now I know why it was not fitting right around the Defrost vent..
The squares in the circled area are suppose to be a small screw hole only.. LOL
Bad Carpet Dye job done before I got the car..
Couple pieces getting prepared to be installed
Old 05-18-2013   #2
Default Re: Dash Pad swap..
Old dash did not fit right around the defrost vent..
Better fit and a hidden GPS antenna now:
New Hush panel on Driver side.
New pass side carpet on Dash:
Old 05-19-2013   #3
Done.. it is a bit better but unfortunately not perfect
Old 06-16-2013   #4
nelson007
nelson007's Avatar
Hello Jeff,
Did you have to remove your dashpad? If so can you tell me how to remove it. I have to remove mine and having problem finding all the fasteners holding it to the frame.
Thanks,
Nelson 007
Old 06-16-2013   #5
to remove.. need to remove:
Pass side trim around Fuse panel
Lower hush panels
Driver side panel against door
Headlight switch
Cluster bezel
all 3 vents
Console and radio bezel
Defrost vent
Glovebox and lid
Dash pad has screws by the center vent, 2 at the defrost vent, 2 above the Cluster
With the vents removed the dash should pull out, it is a bit tight as there are 4 clips along the windshield edge holding it in to the car
Old 06-16-2013   #6
nelson007
nelson007's Avatar
Jeff thanks a million,
I will give it a try tomorrow,and let you know how it turns out.
Have a good evening,
Nelson
