Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Technical Questions
Old 04-20-2005   #1
JDNewYork
Default Bilstein Shocks
I posted this on another forum with no success. So, I'll try here. I want to replace the existing Bilstein shocks on a non-ZR-1 1995 coupe because it appears they have never been replaced. The car handles okay but appears sloppy. I do not think it is the actuators because I do not have a warning light. Bilstein lists two versions of the shocks: one with the Z51 suspension and one without the Z51 package. I could not find a Z51 code for 1995. My car has the FX3 handling package. There is no Z51 code on the original window sticker. What is the Z51 suspension and how does it relate to the FX3? How do I determine if I have the package. Thanks.
JDNewYork
1995 Corvette Coupe
JDNewYork is offline   Reply With Quote
Old 06-17-2005   #2
Maciek
Default
You have FX3 susspension (it's active susspension) it's differend from Z51 and non Z51(base). Z51 and Base haven't actuators. You can buy Bilstein FX3 shocks for example in Mid America or Eckler's but it's 200 $ each ( in GM 400 $ each).
ZR1'91 NOS, Best 1/4 ET 11,53/123 mph
[url]http://www.sss.org.pl/images/biala120605/Data/page.htm?29,0[/url]
Maciek is offline   Reply With Quote
Old 06-24-2005   #3
JDNewYork
Thanks for the input. It is funny that I need to get the info from Poland for a Corvette! Again, thank you.
JDNewYork
1995 Corvette Coupe
Old 06-24-2005   #4
Maciek
Default
You welcome
Old 07-22-2005   #5
Jeffvette
Default
You can send you shocks into Bilstein and have them rebuilt. Costs range from 50-100 per rebuild.
Old 07-27-2005   #6
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
Default
Have you ever done it and what is the turnaround time? Just curious.
Life's too short to be unhappy!
[IMG]http://i4.photobucket.com/albums/y128/koolaid117/Montage.gif[/IMG]
Jim Jones is offline   Reply With Quote
Old 07-28-2005   #7
Jeffvette
Default
3 weeks to a month. Depending upon where you live it's 1 week shipping each way, then 1-2 weeks for the rebuild.
Yes, I've done it and I went with a revalve.
Old 07-31-2005   #8
Hib Halverson
Default
First, forget all this stuff about base and Z51. You don't have either of those. Also, Z51 was not available in 95, anyway. You have Selective Ride Control "SRC" which some refer to as FX3. They are shocks with adjustable damping via a "bypass valve" in side the shock that changes its position according vehicle speed.
SRC is not, as is said elsewhere in this thread, "active suspension". The suspension on your car is p***ive but does have "ride-adaptive dampers" (the generic technical term for SRC).
How many miles are on this 95 and what makes you think the shocks are worn out?
Also, when you key-up, does the "service ride control" light flash once on then go off? If so, the system's electronics are working properly. If the "service ride" light does not flash at all on key-up, the bulb may be burned-out or removed.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 08-02-2005   #9
95ZR1
Default
censor test....
passive
p a s s i v e
assistance
bass
..... nevermind.....
ZR1.Net Founding Member #088
C4: '95 ZR1 #357, black/black, B&B Tri-Flo w/ X-pipe
C6: '07 convertible, Atomic Orange, LS2, 3LT, A6, Z51
Sea Six: '01 Chaparral Sunesta, 5.7L EFI Mercruiser
95ZR1 is offline   Reply With Quote
Old 08-01-2007   #10
Default Re: Bilstein Shocks
Or you can buy them new from eshock.com
