03-04-2013 | #1 |
Jerry's Plenum Gaskets
Just installed ASET of Jerry's thicker plenum gaskets on my 1990 ZR-1. I had a set from Kurt, but got hit in judging for them. Not sure what he issue was, as my wife was with the car when it was judged. Jerry worked up a set of beige thick gaskets for my plenum. I compared these to my original plenum gaskets and the thickness, when installed is just right and they are almost indistinguishable fom the originals
Thanks, Jerry or a great job and super service. Jim |
03-04-2013 | #2 |
Re: Jerry's Plenum Gaskets
they dinged you from plenum gaskets? what did they do, pull the plenum?
03-04-2013 | #3 |
Some way they did not have the right configuration. I haven't really matched them up with the originals, but if they don't appear the same as the originals hen installed, that's a deduct. It's only a point or two, but I'm going for a McClellan in July.
Jim |
03-04-2013 | #4 |
you're a better man then I am jim
03-04-2013 | #5 |
I had to go under to clean and replace the air box gasket, also. This makes the fourth or fifth time for a plenum pull. Glad it's pretty simple Jim |
