Old 10-27-2012   #1
vilant
Default gasket question
I'm in the middle of removing my plenum. My question is: If one of the gaskets for the plenum is intact and the other tore. Would you replace both with new ones or just the torn one?
I heard the originals are the best but I'm unsure.
Joe
1990 Bright Red ZR-1 #2599
Old 10-27-2012   #2
sammy
Default Re: gasket question
replace both with jerrys gaskets, his are every bit as good as the factory's
Old 10-27-2012   #3
scottfab
scottfab's Avatar
Cut your own out of rubber and you'll never have to replace them again.
I did this in the late 90s after experimenting with several other materials.
Same rubber gaskets ever since.
Oh and I'll add it very easy to do with the plenum as a guide.
Scott
Old 10-27-2012   #4
vilant
I did consider doing it that way, but I was a bit lazy. I was already ordering new wires from Jerry so I got the gaskets too.
Joe
Old 10-27-2012   #5
mike100
Jerry's work well, but since they don't have the rubber rings molded into them, I have found that you should permatex/ aviation form-a-gasket the water and oil breather holes to prevent seepage after install.
Of course Jerry's are a must if you port since they are perfectly cut to accommodate 36mm porting.
Old 10-27-2012   #6
Just buy jerry's thicker pairs. GC
GOLDCYLON is online now   Reply With Quote
Old 10-28-2012   #7
vilant
I have to ask, but why permatex? In other words what's the point of the gasket if your going to put permatex around everything. And how do you not make a mess putting the plenum back on w/ permatex on both sides?
Joe
Old 10-28-2012   #8
mike100
Yes, it would be better if they had the rubber o-rings embossed/molded onto them with 36mm cut-outs, but who knows how much that would cost. BTW, I'm only dabbing on the brown sealer in three spots, not on the whole part.
The water port will work with a thin smear of rtv sealer, but the oil breather pass-thrus will soak into the gasket material and weep out the side if you don't dope them with the oil resistant permatex
Old 10-28-2012   #9
vilant
Ahh, I see, makes sense. I was leary of putting it over all of the holes. I'll check to see if the permatex I have is oil resistant, if not I'll run out and buy some. Thanks.
Joe
Old 10-28-2012   #10
mike100
I use this stuff
There are some no-name clones that work the same and are the same exact stuff. I can tell by the smell, actually. When RTV isn't as appropriate, this stuff usually works better. It also seals head bolt threads that go into water jackets- it just about works anywhere.
I had tried rtv before to seal the pcv vents on the I/H's, but unless you can assemble the parts immediately and get them torqued, the rtv might cure before the parts set together creating a small void for oil to follow. This brown goo permatex will give you a lot more time to get it assembled.
