Old 07-17-2012   #1
Default ac compressor locked up
is this something I can tackle myself or do I need to take it to a pro to have them recover the freon?
Old 07-18-2012   #2
scottfab
scottfab's Avatar
Default Re: ac compressor locked up
I don't understand "lock up".
Clutch engages but belt just slips in the pulley?
Scott
Old 07-18-2012   #3
hit the auto button on the dash, car blows hot air and the belt slips
Old 07-18-2012   #4
VetteMed
If compressor is seized, it is possible that the system is still charged, and yes, would require proper recovery of the R12 at a shop.
Once that's recovered, it's not a terrible job to swap the compressor; but the plenum must be removed, and the alternator must be unbolted to allow for access to the compressor mounting bolts.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 07-18-2012   #5
scottfab
scottfab's Avatar
Yup sounds familiar. As far as what to do with "freon", that's your decision. Maybe you can find a place that will remove it quid pro quo. I mean they get the gas free after all. I'm not sure if there is a hit for AC work on this forum under Solutions yet.
There is some A/C help on this page. I did the swap over to R134 about 11yrs ago.
http://www.zr1netregistry.com/ZR1_howto.htm
Scott
