Old 06-30-2012   #1
ghlkal
ghlkal's Avatar
Default How-to Use HVAC Display as Tachometer
Did you know you can check engine RPM on your HVAC (C68) display? Why? Well, my tach is way off and I wanted to see how far. I ordered a Tech 1 which didn’t work, so I’m wondering how could I see how far off the tach was.
As I was troubleshooting an AC problem, I discovered that in addition to displaying HVAC fault codes, the HVAC display could show other parameters too.
In my 1990 FSM, this is on page 1C1-5
To display fault codes from the HVAC system, press and hold both [fan up] and [fan down] buttons simultaneously for 5 seconds. Pressing the [fan auto] button after that will display any HVAC fault codes (eg, I had code 09 – low Freon). Now, if you press [fan up] you can move through a number of additional parameters.
Parameter 6 is engine RPM (RPM / 25). After pressing [fan up] to display “6,” press [fan auto] to see the value.
At idle my tach showed just a tad above 1000 RPM. Parameter 6 on the HVAC showed 26. So 26 * 25 = 650 RPM.
(As a noob, I keep looking for some information that I can share to help pay back all the great info I get here – I searched and looked in solutions, and I didn’t see this … but, it’s probably posted and many of you may know this)
Old 07-01-2012   #2
SteelBlueZR1
Default Re: Use HVAC display as tach
Yes, I just found this too, and I was surprised that my tach was dead on accurate at idle 3k and 5k too. I believe parameter 16 is engine temp in Celsius too.
SteelBlueZR1 is offline   Reply With Quote
Old 07-01-2012   #3
Z Factor
Z Factor's Avatar
Thumbs up Re: Use HVAC display as tach
Reputation points added for an informative post.
Old 07-01-2012   #4
scottfab
scottfab's Avatar
One parameter that is not in the table of the 90MY FSM is #16 which is the water temp in deg C.
Scott
Last edited by scottfab; 11-10-2012 at 11:10 PM. Reason: corrected F to C and added "90MY FSM"
Old 07-01-2012   #5
efnfast
Hey, that's pretty cool. Bonus, my tach appears to be right on.
Old 07-01-2012   #6
ghlkal
ghlkal's Avatar
Originally Posted by scottfab
One parameter that is not in the table is #16 which is the water temp in deg F.
It's either temp in *F / 2 or temp in *C ... I wonder how we can find out?
Here's the page from my FSM for the published parameters ...
Old 07-01-2012   #7
VetteMed
Here's the chart from the 1991 FSM
Parameter 16 is actually the coolant temp in C, not F.
Old 07-01-2012   #8
scottfab
scottfab's Avatar
That may be on a 91 however I have a 90 and is not setup for metric.
(an option on the dash).
On my SW version it reads out in F. (this is wrong, I was reading my notes in the manual and it says
"16 is the water temp not in F". so much for my hand writing.)
Scott
Old 07-01-2012   #9
scottfab
scottfab's Avatar
What is the Serial number of your 90?
Mine reads in F.
But I will double check later this week.
I made a note the manual that it was F.
Scott
Old 07-01-2012   #10
CamP
My '90 reads in Celcius. It's a late production car.
CamP is offline   Reply With Quote
