Old 07-03-2012   #1
VetteMed
Default Re: Master Brake Cylinder ?
I hope I didn't jinx myself. Driving home from work yesterday, my brake pedal was quite soft, with a long travel. Got home, and the forward reservoir was nearly dry (scary!). Today, I inspected the entire system, I can find no evidence of a leak (other than some bubbling caliper powdercoating near the RH front caliper bleeder screw.
Here's where it gets weird.
I bled all 4 calipers -- all the while checking for leaks (none). However, the LH front caliper really didn't give me a good solid fluid stream like the other calipers did, so I'm kind of scratching my head about that one. I did use a vacuum bleeding system, BTW.
So, I tightened the bleeder screws, topped off the fluid, and the brake pedal is now firm as it used to be. I don't get it at all. No signs of leaks anywhere. Perhaps master cylinder leaking into brake booster, only from the front portion of the cylinder? I don't know if that is even possible...
Old 07-03-2012   #2
scottfab
scottfab's Avatar
Had a similar experience using vacuum on an Explorer.
Used the peddle to bleed them and the softness went away.
Scott
Old 07-03-2012   #3
gbrtng
gbrtng's Avatar
Wifey's 91 base car is leaking fluid from the front to the rear reservoir, so
that might be your problem. I just transfer fluid back where it belongs every so often.
