Old 06-13-2012   #21
efnfast
Default Re: Change oil light
I assume changing the bulb means pulling the dash. If I pull the dash, it's time to do all the bulbs. If I decide to pull the dash, it will have to wait until winter. I've never done somthing like that and am not willing to risk not having it back on the road.
Old 06-13-2012   #22
VetteMed
Pulling the cluster is not that difficult.
Drop carpeted hush panel
Drop metal under-dash panel
Remove screws from cluster surround (can't fully remove until column is loosened
drop (but do not remove) steering column (2 big bolts)
4 screws hold cluster in to dash frame, then cluster pulls straight out.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 06-14-2012   #23
batchman
All MYs do this.
Mine happens to be a 90.
I don't think my 91 lights this on Key-on, didn't know it was there until it came on to stay, around 3.5k miles after we bought it. I'll try to verify this.
Cheers,
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's
DRM chip/Watson/Borla/lid/LW batt&headlights,
springs, shocks, pads & lines, quick rack & Turn One,
camber brace, 32/22mm sways, A/C halfway deleted
17x11 & 12 CCW's, 315 & 335 Hoosier A6s
[/I]
Old 06-14-2012   #24
efnfast
I've got a couple other bulbs out, so I'll have to drop the dash. This winter. I'll have to remember this post so I can look for instruction. I never saw this light on until it indicated an oil change. Did it today by the way with Amsoil, poor mechanic got holered at by his boss, we spent over an hour doing an oil change. My regular shop lets me hang around my car while the mechanic works on it. They do an oil change for $20, and I supply the oil, but it gives me the opertunity to get a good look under my car.
Old 06-14-2012   #25
scottfab
scottfab's Avatar
Cheers,
- Jeff
Yah, I'd be curious if the 91 is different from other MYs.
Scott
