Dyno results from beginning of tuning to last session.
![]() ~+20rwhp/+10rwtq Changes include: SW Xpipe DynoMax Ultraflow w Z06 flappers Re-ported IH's I think if I went back again I would lean out fuel just a bit morew some more timing at lower rpms. However, one thing that is disappointing is that it seems from the graph that the dyno operator was lifting at about 6800rpm rather than going thru 7K. Looking at the slope of the curve (blue), it looks like the trajectory may have gone a bit higher. Note how the before ad after lines are increasingly diverging. Last edited by XfireZ51; 06-05-2012 at 03:01 PM. |
![]() Join Date: Mar 2004
20 + 10 that's nice work 1
![]() Join Date: Jan 2009
good AB test with actual data.
Data always beats "feel" for accuracy.
#4 | |
![]() Join Date: Jan 2004
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
![]() Join Date: Aug 2008
Still Dom at 434rwhp I wouldn't be complaining at all. And I take it that's without head work.
![]() Join Date: Jul 2005
Very nice! now it's time for some boost!
![]() Join Date: Jul 2007
no, he has a set of GVD Ported heads on it
#8 | |
This was the rpm output from the dyno connected to ignition. You can see it with the lifting at about 6800rpm. rhipsher, Just to clarify, the motor has Pete's regrind for the intake cams, GVD ported heads and DIY top end porting. A few months ago I listed measurements I made on the GVD porting. In comparison to what Pete and Marc do for porting, I would characterize it as "conservative"(not in the political sense ![]() I think all of the examples we've seen in the last year or so suggests to me that an aggressive head porting (36mm+) is probably the best bang for the HP buck. It's my opinion that my current heads don't take full advantage of the cams. Having said all that, the 434rwhp feels pretty damn good. BTW due to time constraints, these hp #'s were done with coolant temps at 193F. |
#9 | |
#10 |
