#11 |
![]() Join Date: Jul 2005
Lee,
Is that really a Siamese plenum? I thought I saw what looked like stock runners in one of the pics. Do you have a pic of the whole plenum? Or are you going to make this one Siamese? Is it going on your car? ![]() Cheers, RH
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int |
#12 |
![]() Join Date: Mar 2007
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 05-06-2012 at 04:55 PM. |
#13 |
Cool... for some reason the first pic won't work for me only the second shows up which a picture of the bottom of the plenum. From the bottom it looks like it's opened up real nice but it doesn't look to be a Siamese Plenum. I was wondering if you were going to attempt that yourself because I know its takes lots of cutting and welding. I might take a Fabrication Course at the local Community College and learn how to do such things... My daughter wants me to use my VA benefits to get a PHD but I'd rather get a welding certificate!
![]() Cheers, Ron |
#14 | |
![]() Join Date: Jul 2004
1991 #1516 Black/Black davidmkelly.com "Speed is often confused with insight." - Johan Cruijff |
#15 | |
#16 |
Shot through IH into the head
#17 |
#18 |
Copy... I never heard Mono-Runner Plenum in our circles even though it makes sense. In the old days those all were referred to as Siamese Plenums because they combined two ports into one which is the engineering definition of Siamese.
As far as porting goes, again in the old days you had several different levels of port. One of them was the open runner port then known as a "full port" which meant removing all the material between the runners. Even though they didn't refer to this as Siamese it meets the engineering definition of combining two ports however, we always left that designation to what you call the "mono runner." Terminology does change, I just have to get use to it. It took me six months to figure out that when my boy said my car sounded SICK that it was actually a good thing... After all these years I still can learn... ![]() Cheers, Ron ![]() Last edited by RHanselman; 05-07-2012 at 12:08 AM. |
#19 |
final product...
![]() Here is the before...MAP brackets cut off.. ![]()
