Old 04-28-2012   #1
GOFAST
Default Throttle Position Sensor
I had to replace me throttle position sensor on my '95 but unsure how to adjust it. What is the appropriate procedure?
Thanks.
GOFAST is offline   Reply With Quote
Old 04-28-2012   #2
Default Re: Throttle Position Sensor
Thanks.
You need to set the 0 position voltage at about .53-.55v. You do this with ignition ON but motor off. It's easier to do it w a scan tool connected. Can also use digital volt meter. Check your FSM.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-28-2012   #3
VetteMed
Center wire on TPS, should be blue wire, is signal wire. Should have around 0.54 volts at idle, and 4.5 volts at WOT if I recall correctly.
To measure, you can flip back the cover that secures the wires into the connector, use a pick tool to pull the round rubber seal back, and then you'll be able to insert your red (positive) multimeter probe against the metal crimp on the blue wire.
Black probe (negative) of meter goes to any engine ground.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
