10-31-2006 | #1 |
90 zr1 injectors
Need a new set of injectors. Where to buy and options available.
10-31-2006 | #2 |
Re: 90 zr1 injectors
accel injectors...less money..summit racing...
10-31-2006 | #3 |
Most either go with OEM or RC's, but some have recently opted for the Accels because of the cost.
11-01-2006 | #4 |
Where do you get the RC's from?
I cant find them. |
11-01-2006 | #5 |
Also, what about the accel when it comes to durability?
Are they gonna last or go bad like the stockers. I got that crappy gas to worry about. |
11-01-2006 | #6 | |
RC Engineering: http://www.rceng.com/ Accel durability, only time will tell. As that they are designed for the fuels of today they shouldn't suffer from the senstivity to ethanol as the original Multecs. TomC '90ZR1 #792 (w/Accels)
11-01-2006 | #7 |
"SOME" say that the spray pattern on the R/C injectors is more like a squirt from a water pistol..... instead of a wide spray pattern from the stock injectors.
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 |
11-01-2006 | #8 |
Decide to bite the bullet and by from AC-Direct.com.$80 primary and $67 secondaries. Plan on fixing originals and saving them for years from now I hope. Thanks for all of your input.
11-01-2006 | #9 |
Could have bought RC's for less than that, and got a better injector.
Fixing the originals basically ruins them. |
11-01-2006 | #10 | |
My '90 went through 2 sets of GM Originals. Yes, 2 sets in less than 11,000 miles. The previous owner of my car had to replace the primaries at some point, and 3 of the 8 GM AC-Delco replacements failed again. Classic ethanol degredation of internal seals and shorting of coils by ethanol. They may have updated their design since 1990-92, but I could not find anywhere where this was verified. I tried calling my local dealer's parts department, they don't have a clue. They didn't know anything about the fuel injectors, either. TomC '90ZR1 #792
