Old 06-21-2011   #1
VetteMed
Default Motor mount swap questions
I don't think too many folks have changed motor mounts on their Zs, but I have been wondering if the lack of clearance between the #1 header tube and the steering shaft is due to sagging mounts, being that my car has a lot of miles on it. Now, I should have changed the mounts when the headers were off, but I didn't -- so now I'm left with wondering if I'm going to need to pull the headers off in order to change out the mounts or not. Does anyone know if it's doable with the headers (Jeal) in place?
Edit:
It's not doable. Pulling the headers is really not that bad of a job, and it gave the access needed to do this job properly. See later in thread for pics of mounts and more commentary.
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
Old 06-21-2011   #2
Default Re: Motor mount swap questions
Seems like it would easy to unbolt the mounts and jack up the engine with a thick board under the oil pan
Old 06-21-2011   #3
VetteMed
Lee, that's what I was hoping for, I guess I just don't remember how much access there is to the upper bolts. Thanks.
Old 06-21-2011   #4
Manual says both can be removed by jacking up engine...no header removal.
Old 06-21-2011   #5
VetteMed
nice! I didn't think to check the FSM.
Thanks again Lee!
-Andrew
Old 06-21-2011   #6
have to take that back...that was L98....LT-5 says exhaust manifold comes off for both sides
Old 06-21-2011   #7
VetteMed
Well, that's typical for the way things have gone lately... oh well.
Old 06-21-2011   #8
headers might be a different story, a lot more room in there
Old 06-21-2011   #9
VetteMed
Yeah, I just looked at the driver's side, might be doable. Can't tell on the passenger side just from looking from above. Might take some creative use of extensions and wrenches.
Old 06-22-2011   #10
Don't forget the C-beam is attached, making the whole driveline one rigid unit. Jacking up the engine with the c-beam still secured could damage the c-beam or trans. When I tried jacking the engine with all attached, it acted like the motor mounts were still bolted to the frame. I suggest removing the c-beam before trying to jack the engine up. Does the service manual mention anything about that?
