05-27-2011 | #31 |
Re: F!!!! Oil Leak...
Awesome! Thank you. I should be home in and able to start on the car in the next 2 hours. Great way to spend a Friday night huh?
Daniel |
05-29-2011 | #32 |
Hi, I'm new to the forum and have a small oil leak. I think it is coming from a pipe plug below the left cylinder head in the block. The oil drips on an O2 sensor on the left exhaust pipe creating a burning smell. Does anyone know what size Allen wrench will fit it?
Thanks in advance for your help. |
05-30-2011 | #33 |
I had same issue with Cam Position Sesnor...new O-Ring and problem solved
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 05-30-2011 at 02:36 PM. |
05-30-2011 | #34 | |
Not a bad job: Remove serpentine belt Unbolt belt tensioner Remove oil cooler lines Unclip 3 electrical connections on filter housing Remove bolts for oil filter housing (3 down low, one up high). an $8 gasket from Jerry for the filter housing, and you're good to go. Andrew
2004 Z06/Z16 LeMans Commemorative Edition 1991 ZR-1 #302 White/Gray (sold) 1991 ZR-1 #1147 Red/Saddle (sold) |
05-30-2011 | #35 |
I'll drink to that....
1994 ZR-1 # 0102...SOLD |
05-30-2011 | #36 | |
05-31-2011 | #37 |
Well It took all of about 30 minutes with the correct tool and the sensor was changed and I haven't had another issue with the ZR-1 at all. Thanks for the help from everyone and Jerry Thank you for the part and gasket!!!!
Daniel |
