04-20-2011 | #11 |
Re: FX3 Woes
Jeff
How much were the Shocks? Corvette central? Another 1990/1991 owner might need them Thanks David |
04-20-2011 | #12 |
Re: FX3 Woes
I got them at Corvette America.. list is $207.99 But I am able to go through a member of my local club that handles the club orders and I go a discount on them, I forget exactly what I paid, but it was better then any other place I looked
04-20-2011 | #13 |
Re: FX3 Woes
This is where I got mine. Check out the link, go to the bottom of the page.
http://eshocks.com/bil_veh.asp?Model...tein&SubChar=Q bottom is for 89 - 91, the rest are about at the middle of the page.
04-20-2011 | #14 | |
Re: FX3 Woes
04-20-2011 | #15 | |
Re: FX3 Woes
Once I pull the Pass Side, I will match it to the ones I removed ( I had all the extra pieces) and will see if I can get the pass side working.. then move back to the driver side
04-20-2011 | #16 |
Re: FX3 Woes
FIXED!!
right side gear was not set right, which I knew. So I fixed that, adjusted the coilover height and put it back together. Now, I had codes 33 & 34, on Sunday when I fixed the Left side, I tried to clear codes and expected 33 to go away but 34 to remain, but I still had both 33 & 34. so after I got the right side done and mostly mounted I thought I should test before fully assembling.. Get the keys and what do you know.. ALL COdes are cleared. I find it odd that I could not clear the left but once both were fixed they all cleared. I am not complaining.. glad it is good to go
04-21-2011 | #17 |
Re: FX3 Woes
Cool!
