Old 04-03-2011   #1
Aurora40
Aurora40's Avatar
Default FS: random bunch of parts
Shipping costs to be whatever they actually are, probably $5-10 for any bundle of smaller things.
Anything with a part number is brand new in the GM packaging unless otherwise stated.
Anything in grey is sold.
  • Steering piece (horn wire is held in by this) 26047013: $15
  • thepartsladi "Delphi" fuel pump assembly (new): $150
  • fuel pump gasket 25091503: $10
  • fuel filler boot NLA 14076115: $30
  • PCV "F" duct I bought new a couple years ago and used, still firm rubber: $40
  • PCV "F" duct, the original, soft, and didn't seal well (used ziptie to hold it tight on valves): $10
  • PCV bottom hose, original from the car but worked fine: $30
  • PCV elbows 14078872 x 3: $6 each
  • MAP sensor bracket NLA (new, but not in a GM bag): $35
  • Wheel locks w/ key: $40
  • brake pins NLA 10140666 x 2: $10 each
  • brake clips 10132842 x 2: $5 each
  • braided brake line from master cyl NLA 10222294, I believe it's made by Vintage Parts, though I bought it from a GM dealer.: $70
  • Earl's braided brake lines, both fronts, right rear, brand new. Will fit any year ZR-1, but it's the early year style, no goofy spring things on the fronts: $20 each
  • Standard Products VSS SC8, new: $35
I also have a wheel and tire that is part of the '08+ CTS spare tire kit. Wheel is a 5-spoke 18x4" and should clear lots of brake setups. Tire is T135/70-R18 and is the same overall height as the factory tires. The hub needs to be bored out slightly, the CTS uses a narrower hub than the Corvette. I never got around to doing that, and don't want to now in case a CTS guy wants to buy it. I can get pictures and details if there is any interest. Spare tire kit from GM is $250-300 P/N: 19179359 (includes a jack, wrench, trunk tray but I've used those in my CTS), I'd like to get $100 plus shipping for just the wheel and tire (they are separate, never been mounted).
Bob Saveland
Former owner of #2517
Old 04-03-2011   #2
Default Re: FS: random bunch of parts
I''l take the elbows are these the ones that go into the side between the cam covers and the plenum ? And the brake pins and clips?
Old 04-03-2011   #3
Aurora40
Aurora40's Avatar
The elbows are the small ones that come out of the injector housings. Not the large ones that come out of the valley breather box.
Bob Saveland
Old 04-03-2011   #4
Those are the ones I want. the 90 degree elbows that come out of the IJHs
Old 04-03-2011   #5
Bob,
this :
is sending unit and all?
Let me know shipping to 60103
Old 04-03-2011   #6
Aurora40
Aurora40's Avatar
Bob,
this :
Yes, the whole assembly. I'm guessing it'd be like $10-15 to ship. I can let you know after I ship it what it cost, and you can send me a check then, if you'd like.
Bob Saveland
Old 04-03-2011   #7
VetteMed
Fuel filler boot - is this new? If so I'll take it.
Old 04-04-2011   #8
Aurora40
Aurora40's Avatar
fuel pump is still available
Bob Saveland
Old 04-09-2011   #9
Thumbs up Re: FS: random bunch of parts
Bob thanks I received the parts. ALL mint in GM bags.
Old 04-09-2011   #10
VetteMed
Same here, mint condition NOS!
2004 Z06/Z16 LeMans Commemorative Edition
1991 ZR-1 #302 White/Gray (sold)
1991 ZR-1 #1147 Red/Saddle (sold)
