Old 03-25-2011   #1
Default CAM Regrinds are back
Got my regrinds back: Intake: Primary 222/415 lift Secondary 236/425 Exhaust 222/415 lift
Regrind is on bottom, stock cam on top
Rerind on Left
Regrind on left
Old 03-25-2011   #2
Default Re: CAM Regrinds are back
To many people the process of regrinding a camshaft is a black art, resulting in the inevitable
question :
?How can you machine metal away from a cam, yet have it finish up with more duration and lift??
It works like this?
In (Fig. 83), the outer contour represents the
original lobe shape and the cam lift is represented
as dimension ?A?, the difference between the base
circle radius and the nose.
The duration of the lift is shown as 120 degrees at
the cam, which would be 240 degrees at the
crankshaft, because the camshaft rotates at half
crank speed.
The inner contour line shows the cam shape after it
has been reground and it can be clearly seen that
the lift has now been increased to the dimension
?B?, this time the difference between the new basic circle radius and the nose.
At the same time the duration has been increased to 160 degrees at the cam, that is 320 degrees at
the camshaft.
From this diagram it is also now possible to see why the cast iron cam lends itself so readily
Old 03-25-2011   #3
sammy
maybe a dumb ? but do you still use the stk lifters or do you have to get a special set ?
Old 03-25-2011   #4
I will need to check cams/lifters to see if they will work, as my heads have had 2 valve jobs, OEM lifters were alittle tall, this may solve that problem.
Old 03-25-2011   #5
Locobob
What is the difference in base circle?
Robert
Old 03-26-2011   #6
Looks like its abouty a 1.-1.2mm difference
Old 03-26-2011   #7
todesengel
Looks like you are getting everything in just in time for a late spring/early summer install. Will be interested to see how it all works out for ya.
todesengel is offline   Reply With Quote
Old 03-26-2011   #8
Locobob
Is that diameter or radius?
I think I recall someone (probably Pete) saying that our lifters had about .06in worth of preload (room).
1-1.2mm = .04-.047in
If this is diameter then there should be no problem as the lifter would only have to make up for .02-.0235in
If it's radius then it still should be okay although seating the valves slightly deeper would provide a little extra comfort.
Robert
Old 03-26-2011   #9
Doesn't the ramp angle also increase and require increased cam torque to rotate the camshaft?
Old 03-27-2011   #10
Coupe89
I'm wondering if I got this right.
Do you need to install smaller cam bearing if you do this?
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
