Old 02-13-2011   #1
Default 368 parts
What all do I need for a 368...
LA Sleeve/4": $1200
JE Pistons: Part #?
Rods: Part/Manufacturer????
Cost of Hone the Block????
Old 02-13-2011   #2
Pete
Pete's Avatar
Default Re: 368 parts
Why?
you can use stock rods if you want.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-13-2011   #3
So I just need Pistons/Sleeves and honing?
Old 02-13-2011   #4
Pete
Pete's Avatar
balancing
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 02-13-2011   #5
Polo-1
Lee I can hook you up with a set of 368 JE pistons for stock rods and the crank that they were run on (balanced for 368 ). You should also ask me about the 380ci motor option :-)
Old 02-13-2011   #6
Let me know your thoughts on price....thanks
Old 02-13-2011   #7
scholtmj
scholtmj's Avatar
Do performance LT5 parts grow on trees in WA?? Tell us more about this 380 option....
scholtmj is offline   Reply With Quote
Old 02-13-2011   #8
Polo-1
I just have a bunch of stuff, still...
As far as the 377/383ci goes it uses the stock crank. Doing a 368 and not jumping up to the 377/383 is nuts. The cost is under $400. The added torque on the motor will jump from 370's to 420's. Lets put it this way, you spend $15.5 to get a 368 and you left up 50rwtq on table for only $400. The build cost the same ( - the $400).
King Bearing makes the special rod bearings that are 1 piece, this is a big plus. This stops the need to buy aftermarket rods ( more money not needed at this power level ).
Old 02-14-2011   #9
sammy
are you talking about offset grinding the crank?
Old 02-14-2011   #10
Thumbs up Re: 368 parts
Ah motor porn!!!! Im going the 380 route with Kevins help already. Best bang for the buck on a budget stroker. GC
