Old 11-30-2010   #1
VetteMed
Default Update on my hi-miler Z project
After 6 months of wrenching and spending money on parts, 1991 #302 is getting close to being driveable again. For those unfamiliar, I bought this car sight unseen from the original owner in CA, with 188k miles on it, for $9700. It already had a Fluidyne radiator, and a 92+ FX3 system with Bilstein modified programming.
Since then, I've done:
All 4 hubs replaced with NOS
Oil cooler lines replaced
Rear suspension redone with Banski rod-ends
Front suspension redone with poly bushings and Moog Tierod ends
ZFDoc short shifter with lockout retained
New lube, new plugs, and new rear seal on ZF
New oil pan gasket, breather box gasket, oil filter housing gasket
New water pump
New coils, plugs, wires
FIC reconditioned Bosch injectors
93-95 Injector housings with mild cleanup of injector bosses
New fuel system o-rings, new fuel filter, new Bosch Turbine fuel pumps, new sender assembly
C5 brakes in front, with powerslot rotors, and powerslot rotors in rear
DRM Brake bias spring
Braided stainless brake lines
Jeal headers, swain tech coated
New AC compressor, condensor, evaporator, accumulator
Painted top end LGAFF-style
Floorpan repairs (careless jacking some time ago)
Interior cleaned - replaced some carpet pieces with 94+ TruVette style carpet, other stock pieces cleaned.
'96 Collector Edition sport seats
Repaired or replaced numerous electrical connectors that had become brittle and cracked
Deleted Secondary throttle blades and associated hardware
Rebuilt starter
Rebuilt alternator
Marc Haibeck PROM
A-molds
New Spicer u-joints all around
New pinion seal, and stub axle seals in rearend, plus new lube
ZFDoc Beam Plates
New shifter lower boot and bellows
There's still lots more to come, but I haven't given any updates lately... here's a couple of pics, as it sits now:
Old 11-30-2010   #2
Default Re: Update on my hi-miler Z project
Wow is all I can say....great work! Glad you kept it!
Old 11-30-2010   #3
scholtmj
scholtmj's Avatar
You worked your A$$ off, Andrew. Great job, almost done!
Just to be clear, you have not touched the internals of the motor? Just supporting maintenance items? I'm curious to see how long a stock LT5 will motor along!
scholtmj is offline   Reply With Quote
Old 11-30-2010   #4
according to tests, 250k, at least
Old 12-01-2010   #5
VetteMed
Thanks, Matt! The motor internals are all stock, untouched by the PO or me. Other than a timing chain guide that lost a piece off of the end, things looked pretty good in there - when I changed the oil pan gasket, I could still see the cross-hatching on the cylinder walls. So we'll see how it goes
Old 12-01-2010   #6
VetteMed
Super nice job......
Great list of restorations
I know about farm trucks
Keep us posted on this one..........In Solutions under the Heading RESTORATIONS http://www.zr1.net/forum/showthread....9454&post89454
Thanks for the support, guys! Let's hope for 250k
Old 12-01-2010   #7
Awesome Andrew !
Old 12-01-2010   #8
Hammer
Hammer's Avatar
Talking Re: Update on my hi-miler Z project
Cross hatch remaining at 189k is unf*&^ingbelievable. Nice job.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I]
[I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I]
[FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT]
[I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B])
1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I]
Old 12-01-2010   #9
Blue Flame Restorations
Really neat stuff!
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-01-2010   #10
Congrats on the hours invested on the refurb -- Looking pretty choice at this point!
http://i119.photobucket.com/albums/o...9mcw/SIG-2.jpg
http://i119.photobucket.com/albums/o128/wb9mcw/vcm.gif
"The Budget should be balanced, the Treasury should be refilled, public debt should be reduced, the arrogance of officialdom should be tempered and controlled, and the assistance to foreign lands should be curtailed, lest Rome will become bankrupt. People must again learn to work instead of living on public assistance." - Cicero, 55 BC
" We the people are the rightful masters of both Congress and the courts, not to overthrow the Constitution but to overthrow the men who pervert the Constitution." - Abraham Lincoln
