Old 02-20-2009   #1
Unhappy Help 91 Random Tech or Magnaflow cats Part number
Need a little help. I believe that I lost my drivers side cat this week. Sounds like a chock full O nuts around the resonator area. Figures as emissions is due on the 15th frankly the last 30 days of my life have been pure hell so it figures. Does anyone know the correct part numbers for the Magnaflows and the Random tech cats? I beleive the part numbers for the Magnaflows are 94006 for both sides but I am not sure. Im tired of dorking around with used cats so it maybe time to hang the set of JEALs. If anybody knows this off the top of thier heads PLMK and thanks GC
Old 02-20-2009   #2
Sgreg
Sgreg's Avatar
Default Re: Help 91 Random Tech or Magnaflow cats Part number
Gold One, if you do the switch to an AF cat and the Jeals you have been sitting on, I have 4 new stainless steel 3 inch reduction pipes that will make fitting to your exhaust much easier. May save extensive cutting and piecing. I have about $80 in the pieces but will take $40 plus cheap shipping for them. Best money you will ever spend. Makes headers and cats fit like factory.
G.
Sgreg is offline   Reply With Quote
Old 02-20-2009   #3
G.
Awesome Greg is this needed because the Jeals are a three inches on the down pipe side and I beleive my Corsa system is a 2.5? If so sold and thanks Greg as I said its been a tough month!!!! Also update!! The Car failed emissions and the coffecan full of nuts and bolts is getting louder I think the Drivers side cat ran out of it lives.
Does anybody here have a set of aftermarket cats they want to get rid of? Either model best price I have found yet is $65 each for the MFs.
Old 02-20-2009   #4
Sgreg
Sgreg's Avatar
Awesome Greg is this needed because the jeals are a three inches on the down pipe side and I beleive my Corsa system is a 2.5? IF so sold and thanks Greg as I said its been a tough month!!!! Aslo update car fail emissions and the coffecans getting louder I think the Drivers side cat ran out of it lives.
Pretty much as you said. Stepping down from 3 inches to 2 1/2 inches. Makes life much easier. Also aids in the fit as two of the pipes are designed to clear stuff underneath. PP $50 shipped. PM me if you decide to go this route.
Old 02-20-2009   #5
jonszr1
jonszr1's Avatar
daryl .,just a word of caution .if that cat has started to break up ,please be carefull as the cat material can work its way back into your motor with very bad results .just didnt want anything bad to happen to your motor . with you having a bad month didnt want to see one more thing go wrong .
Old 02-20-2009   #6
Jeffvette
Just a FYI for anybody searching in the future here are the numbers
MPE-59959 7.75" length
MPE-59929 11" length
3 inch in, 3 inch out metallic substrate
Old 02-20-2009   #7
Jagdpanzer
Jagdpanzer's Avatar
Here is an example of 3" Magnaflow MPE-59959 7.75" length cats connected to a 2.5" Corsa system using Stainless Works SS transitions http://www.stainlessworks.net/cart/p...oducts_id=1295
Old 02-20-2009   #8
Thanks for that illustration. Thats what I was thinking it would look like. Ok update im going with the Jeals and I was able to pickup a set of Magnaflow cats 59959s for $137.36 Shipped. Let see if I get a performance pick up on this after this is done as well.... and pass emissions. Thanks for all the help. GC
Old 02-20-2009   #9
I like those transitions
Old 02-20-2009   #10
Gunny
Gunny's Avatar
G.
Are all 4 reduction pipes spoken for? I am looking for the best solution (i.e. fewest headaches) to hook up 2.5" Corsas to 3" headers/cats.
George
