08-11-2020 | #1 |
Question on Cluster LCD Panel Backlighting
Okay all I need your input..
ON your corvette, key on, parking lights OFF.. what does your LCD backlight do? Is it on? is it off? also need year of car THANKS PS< I know what my 1990 does, so curious on other years
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Flowmaster Cats - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 08-12-2020 at 02:28 PM. |
08-12-2020 | #2 |
Re: Question on Cluster LCD Panel Backlighting
My 90 the light is very dim in the garage once i pull it out in the day light it gets bright once i turn the lights on very bright. My 91 its always bright no matter what lighting.
90 Chevy ZR1 LPE #2315 'SOLD' 90 Chevy ZR1 LPE #2774 'SOLD' 91 Chevy ZR1 Callaway aerobody 91 Chevy ZR1 #1512 91 Chevy ZR1 #951 95 Chevy ZR1 #338 'SOLD' 91 BMW 850i 94 BMW 850csi 95 BMW 850csi 94 Lotus Esprit S4 07 Benz CLS550 06 BMW M5 "SOLD" |
08-12-2020 | #3 |
92 with key on, parking lights off in the garage. And yes, this time dusted off the steering console
08-12-2020 | #4 | |
Thanks
08-12-2020 | #5 |
SO looking into it a bit more.. my backlight only works with the parking lights on. I know the Photo sensors work.. so it is either a bad wire to the CCM, or the CCM is bad for that circuit, I am hoping it is just a wire.
08-12-2020 | #6 |
Yes in garage low light it is Dim once its out in day light its fine.
08-12-2020 | #7 |
My '92 it's on bright in garage or outside. Only time it goes dim is w/ headlights on when it's dark outside.
09-10-2020 | #8 |
Fixed.. easy one luckily.. just needed to reseat the connector on the info center
09-05-2022 | #9 |
revisiting this...
LCD Dim in the the garage and while driving. Photosensor works, if in the daytime I shine a light into sensor LCD gets bright, remove light it gets dim, I need another favor for those with 1991-newer. My guess is checking this in the garage will be most noticeable.. key on- Not running, are the gauges backlit as well? If you adjust the brightness on the interior lights (light switch is off) does the dash get dimmer or brighter as the light dimmer is adjusted? Thanks
09-05-2022 | #10 |
92, in the garage, key on not running. Gauges are backlit. No change in brightness if the light dimmer is adjusted.
Thread Tools | |
Display Modes | |
