![]() Join Date: Dec 2005
Finally was able to take my 1990 out this summer for a drive. I noticed at lower RPMs (idle-2000) when you apply the gas petal it hesitates and stumbles then catches. Replaced injectors with FICs about 3 -4 years ago. I only put about 3-4000 miles a year on the car. Does this sound like plug wires or plugs? No codes. Could the injectors go out in this short of time? Is there something I am not thinking of??
Thanks in advance for your thoughts.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
![]() Join Date: Jul 2007
Old gas? or all fresh?
I filled the tank at the end of last season with premium and added fuel stabilizer per directions. I thought I had read a post that the tank should be full for winter storage? Could this damage the injectors?
no, I always store with full tank, just trying to get a gauge for the fuel.. I got a tank of bad gas (from BP) recently.. first time I every had an issue..
No codes.. hmmm, you have a scanner to see what the car is doing?
#5 | |
Thanks again.
I had the same problem with my 90' Check the throttle position sensor.
#7 | |
Thanks
![]() Join Date: Sep 2016
Time for Italian Tune Up?
#9 |
![]() Join Date: Feb 2011
#10 | |
He is also lending me his fuel pump jumper to see if the primary pump is going. I missed out on the jumper buy. Soon as it comes by snail mail I am going to check that and then also get a loaner pressure gauge to check that. If fuel pump is ruled out then I might try your advice.
Thread Tools | |
Display Modes | |
