Looking for photo or detail description of where the two relays and yellow connector shown are located (1990 ZR-1).
The two relays have a "slip in" mail connector as can be seen. In general the Relays are on drivers side right of steering above hush panel but......cannot locate mating attachments for either relay or yellow connector (what is the yellow connector?). ![]() ![]() c4koh has provided this detail photo of the drivers side flasher ![]() I assume his photo also shows two or three relays between the flasher and steering column?? Cannot see much to the right of the steering column regarding relays??
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-24-2020 at 06:48 PM. |
![]() Join Date: Jul 2007
The Yellow connector is the Air bag connection
I need to reference the FSM for the relays though. but I believ they are Bose Amp and Fuel pump (forget if it is #1 or #2)
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
#3 | |
Now to figure out how to get under there (remove the seat?) so I can see where they might be attached to a Fixed Bracket ![]() I did not want to take another 90' apart to see where they are attached ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-24-2020 at 11:52 PM. |
they slide on to the holder and the holder I believe slides into place as well
Maybe the Fixed Bracket is missing on this 90' ????
I will post up photos when I figure it out if I can hold my cell phone under there ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-24-2020 at 11:51 PM. |
![]() ![]() Join Date: Aug 2005
I'm not sure if this will help, but years ago I was looking
all over for my rear turn flasher in the same area. Jeffvette told me that it was behind a diagonal metal dash brace. http://www.zr1.net/forum/showthread....hlight=flasher Once I removed this brace the relay block was easily visible and reach-able. Good Luck! Ted
1995 ZR-1 #106 Blk/ Blk Owned by me since 2000. 93K miles, but not on motor :-) Mods the way I want it, Not afraid to drive it! |
#7 | |
That photo I found (above) is from your thread 👍 And........looking closer one of the relays can be seen upper right hand corner in that photo 👍👍👍 Removed the Front Support Bracket and everything is exposed and easy to get to as you suggest. ![]() Found that the Relay Fixed Bracket tabs were broken so just replaced the Fixed Bracket. On a 90' there are two Relays left and two Relays right of steering column. Each pair of Relays are slip locked together and then slipped into lock position on the Fixed Bracket. Shown below after the FIX ![]() The Fixed Relays are facing to the rear of the car on the right side of steering column. ![]() ![]() Post 292 - Locating Relays Above Drivers Side footwell
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-24-2020 at 11:55 PM. |
Thread Tools | |
Display Modes | |
