Old 05-22-2019   #1
bvectra
Default wtb speedo gear
looking for the stock speedo gear for a 92 zf6 6speed and 345 rear gear
bvectra is offline   Reply With Quote
Old 05-23-2019   #2
owwdee
owwdee's Avatar
Default Re: wtb speedo gear
I believe I have one. I can check this evening. I think it is green 42 tooth.
1991 ZR-1 #1900
Black/Black
owwdee is offline   Reply With Quote
Old 05-23-2019   #3
bvectra
let me know and how much
Old 05-23-2019   #4
owwdee
owwdee's Avatar
So I have a green 44 tooth. It is possible that it is not the original out of my 91. I’ll have to check the parts list to see what I have and whether it is for the original 3.45 ratio or not. I will update tomorrow.
Not sure on price either. Maybe $50? I know the correction gears from Mr. Haibeck are a bit more. I also have the 15 tooth drive gear which should be the original.
1991 ZR-1 #1900
Black/Black
Old 05-23-2019   #5
owwdee
owwdee's Avatar
1991 ZR-1 #1900
Black/Black
Old 05-24-2019   #6
owwdee
owwdee's Avatar
I think you need the 42 tooth for a stock 3.45 rear. I have found part no 25513049. The 44 tooth I have looks like it may be from a 700R4! Yah! Previous owner had quite the sh** show for the speedo and rear end before I fixed it (had a 4.55 haha). Anyways, hopefully someone else has one that can help you out. If you need the drive gear (15 tooth) I can sell that to you. Good luck with your search.
1991 ZR-1 #1900
Black/Black
