Old 02-06-2017   #1
henryr
Default street / track alignment
i plan on taking the 90 out for a track day at road atlanta.
anyone have a suggestion for an aggressive street / track alignment?
henryr is offline   Reply With Quote
Old 02-06-2017   #2
henryr
Default Re: street / track alignment
never mind found some links in searches
Old 02-06-2017   #3
Kevin
Kevin's Avatar
there's also a place in the owners kit that tells you the settings
Old 02-06-2017   #4
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
https://www.vbandp.com/instructions/...pecs/file.html
Great info!
Marty
Old 02-06-2017   #5
henryr
danka....
what about lowering this thing a bit ?
Old 02-07-2017   #6
RussMcB
Originally Posted by henryr View Post
danka....
Are you a member of the ZR-1 Registry? If yes, there is a good article in the recent quarterly issue in the Members Only section:
http://www.zr1netregistry.com/Member...ewsletter.aspx
I bought the commonly available kit with the longer bolts that allow you to lower the rear (my front is low enough so I left it as is).
When are you going to Road Atlanta?
Old 02-07-2017   #7
henryr
i am not but that is on my list
chin has two upcoming events end of Feb and in March
Old 02-07-2017   #8
mike100
I would suggest lowering the fronts with coil overs. There aren't very many unmolested ZR-1 front springs left. Don't cut the rubber bushing off of yours to find out you don't like how low it rides or how much softer the preload on the spring gets.
The lowering bolts on the rear are super easy and a half hour job to swap back.
