10-02-2016 | #1 |
Belts and Pulleys
After my Water Pump pulley debacle, I had put on a new Continental Belt, #4060802.
Popped the hood the other day to take a look around, and noticed the belt was sitting on the alternator pulley a little funny. Pulled the belt off to inspect it, and saw this nice split lengthwise on the belt: So, I've got something eating up this belt. I'm inclined to say pulley alignment or something like that. However, I did notice that the alternator pulley has 4 peaks and 5 valleys. All other pulleys have 5 peaks and 6 valleys. Belt matches the 5/6 pattern. I took a look at the alternator picture at Jerry's Gaskets, and it looks like that pulley has the 5/6 pattern. What do we think? Do I need a new pulley, a new alternator, or just a new belt?
1991 ZR-1 #1438 Black/Black & Red |
10-02-2016 | #2 |
Belts and Pulleys
Install new alternator pulley with 5 peaks and same diameter.
Use a 15/16 inch offset box wrench and 8mm allen wrench to remove altrnator pulley. Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-02-2016 at 02:57 PM. |
10-02-2016 | #3 |
Re: Belts and Pulleys
Thanks. Went out to double check the 15/16" number and noticed that there's a current rating stamped on the alternator. Mine says 108A. Aren't the alternators for these cars supposed to be 120A? Any issues running a lower max current?
Sent from my iPad using ZR-1 Net Registry
10-02-2016 | #4 |
Fair enough. I've had the car two years (seasons) now and it's done OK. Some voltage gauge fluctuations at idle, but I've chalked that up to normal C4 stuff up to this point.
I may swap the pulley in the short term, then look at swapping the alternator over the winter. Thanks! Sent from my XT1030 using ZR-1 Net Registry mobile app
10-11-2016 | #5 |
Alrighty then. I decided I'd be better off just replacing the alternator now while I've got the chance.
I ordered one from O'reilly (R111799B) ...which I see now is different than R111799A mentioned above. However, the website pointed me at the B version... Update July 2017: Ordered an alternator R111799B at O'reilly in-store, and it arrived with the appropriate pulley. When I received the alternator the pulley was too small in diameter (56mm vs the needed 62mm). I went to my local O'reilly, and they helped me order a replacement. Same problem there, so I returned it and did some more research. Based on some product pictures I was seeing, it looked like there was an AC Delco rebuild that had a promising looking pulley. I called around until I found a shop that had one, and had them measure the pulley for me. Bingo, 62mm. I ordered it, and just got done installing it, and my new belt is very glad for it. So to make a long story short, the AC Delco 334-2318 is a proper fit off-the-shelf for the ZR-1, pulley and all. Also, I did this replacement without pulling the plenum or throttle body. [Tools used in square brackets]
1991 ZR-1 #1438 Black/Black & Red Last edited by KPW; 07-08-2017 at 04:21 PM. Reason: Step #4 marked as optional, as I was able to perform a parking-lot alternator swap without removing the belt tensioner from the vehicle. |
10-12-2016 | #6 | |
10-13-2016 | #7 | |
The Pulley on my rebuilt alternator was not the correct diameter so this is getting confusing. I think the correct outside diameter on the face of the pulley is 2.75 inches. Like your write up on Alternator Replacement without pulling plenum In the mean time I am making a tool to quickly remove that Alternator Pulley such that no matter which pulley is on the rebuilt alternator I can just switch pulleys during the exchange
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-13-2016 at 07:33 PM. |
10-13-2016 | #8 |
Dyno, you're right on the 2.75 inches. There was some serious pulley confusion on my end as well. Glad it's behind me for the moment!
10-18-2016 | #9 | |
Also...........Note the All Aluminum Belt Tensioner Pulley below the All Aluminum Alternator Pulley. See All Aluminum Alternator Pulley
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-18-2016 at 08:56 PM. |
02-11-2017 | #10 |
KPW just finished replacing an alternator using your method. It worked. Getting the extra deep socket for my oil pressure sensor and swapping pulleys took longer then the replacement.Thanks again.
Gary 90-1572 |
Thread Tools | |
Display Modes | |
