03-02-2016 | #1 |
Am I ready to install my headers?
Ok, from now on I got:
-Exhaust manifolds gaskets -Paul's dipstick bracket -OBX headers -Patience Haven't received the headers yet though, will I need to have them surfaced? I will also need to order a chip from Marc Haibeck. Do I need something else? Bolts? o2 harness extension? Permatex? Thanks! Last edited by MuRCieLaGo; 03-02-2016 at 05:19 PM. |
03-02-2016 | #2 |
Re: Am I ready to install my headers?
Yes. You'll need that too!
03-02-2016 | #3 |
Paul, I'm not sure what you mean by "that".
03-02-2016 | #4 |
Bolts - YES
O2 Extension - YES Permatex - Always good to keep on hand
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
03-02-2016 | #5 |
Dipstick grommet from Jerry (unless you're very careful & lucky)
Ted |
03-02-2016 | #6 |
My 94 did not need O2 sensor extension. I believe OBX headers, due to fake cats, O2 sensor bungs are 3-4 inches forward compared to Stainlessworks headers.
Any other OBX header users remember different? Also, I used Permatex high temp copper sealant per Phil's recommendation. Seems to help the seal and keep the bolts from vibrating loose. Although I used Stage 8 bolts with locking tabs, Phil's suggestion was not to use the locking tabs since header gasket tends to shrink at times necessitating re-torquing of header bolts - impossible once locking tabs are used. However, there are two bolts impossible to get to once dip stick bracket is installed. For those bolts I used the locking tabs knowing I won't be able to re-torque. Last edited by secondchance; 03-02-2016 at 09:46 PM. |
03-02-2016 | #7 |
Sorry.... I wuz just havin fun wid ya!
=Jeff= filled in the blanks.
03-02-2016 | #8 |
03-03-2016 | #9 |
My 90 needed O2 extension.
My stage 8 fasteners, the locking clips would not fit in the groove, so not locking. In my case they served no purpose making for some expensive header bolts. I also ended up shimming the engine at the motor mounts to clear the steering shaft, the ceramic coated headers rubbed the steering shaft. |
03-03-2016 | #10 |
I cannot answer that as I had purchased used Watson Headers and just bolted them on..
Thread Tools | |
Display Modes | |
