02-17-2015 | #1 |
Cant stand this dipstick. Any alternatives? screw in or clip on handles available?
Seems like the dipstick handle always is off and doesn't have a positive 'click' in place on the tube. Drives me crazy. Are there any alternatives available? Im debating on sending out my tube and having a new threaded tube and dipstick made so it can be screwed on.
02-17-2015 | #2 |
Re: Cant stand this dipstick. Any alternatives? screw in or clip on handles available
cvette98pacecar is looking into Billet handles. See thread in Parts for sale/ wanted.
02-17-2015 | #3 |
That would be nice but would the handle alone have a secure way of staying put ie click, or screwed on the tube? I sent a few emails out to custom makers I might pull my tube and stick and send them out to have it done. Will check out the thread though thanks!
02-17-2015 | #4 | |
You may have too much positive crankcase pressure/blow by. I do not recall a positive click but one way to keep your dipstick in place is to bend the dipstick a bit (about six inches from the end or even near the top) so it keeps itself in place within the dipstick tube. Bending the dipstick does not damage the dipstick as it bends itself as you insert it in the dipstick tube. Just bend the dipstick a bit more near one end or the other until there is enough resistance to keep the dipstick in place.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-17-2015 at 12:36 PM. |
02-17-2015 | #5 |
My streetrod and Boss Hoss both had billet Lokar units. Best aftermarket dipsticks I've seen,so far.
Clint & Sherry 1994 ZR-1 White/Red #152 (sold) 1991 ZR-1 Callaway Aerobody #1332 (sold) 1990 ZR-1 Red/Red #952 (sold) 2002 Z06 Torch Red/Mod Red widebody |
02-17-2015 | #6 | |
Lokar is one I have an order for my billet pan on my other car I may have them do one for the z that will screw on. |
02-17-2015 | #7 |
Happens when you add headers, as this repositions the dipstick tube, which is why you have to fab a new bracket (or buy one of Paul's). Mine would click into place but then would always unseat after only a very short drive. Don't know how to fix it, but that's the primary cause. Very frustrating, indeed.
02-17-2015 | #8 |
HI,
I had the same trouble (Jeal Headers) Made a clip that attaches to the top of dip stick with a small spring fastened to the header bolt. So far it has not come off. To check oil remove clip check oil return clip to top of dip stick handle. Sorry i do not have a pic. 1990 white/black # 2546 one of a few auto (4l80E ) eq. ZR-1's John |
02-17-2015 | #9 |
HawaiiZR-1 has a Lokar on his car
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - Borla Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
02-20-2015 | #10 | |
this!!! I had problems with the c5 dipstick and went to a lokar works fantastic with a bearing collar for a positive retention on the dip stick only down side is the billet alum knob gets too hot!! not an issue on the lt5 which should be checked after a good drain down and cool anyway if anyone has the right part number for the lokar on a z it's on my upgrade list!
Thread Tools | |
Display Modes | |
