Old 02-11-2015   #1
FI250
Default ECM Chip
WTB original chip for a 1990 ZR1.
FI250 is offline   Reply With Quote
Old 02-11-2015   #2
Default Re: ECM Chip
Make sure it has the GM update and is a later chip
Old 02-11-2015   #3
Any chip will do, just needs to have the correct calibration burned on it.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-11-2015   #4
Z06scentair
Z06scentair's Avatar
I would suggest for the original chip you may call Marc Haibeck and see if he has what you need.
Original for NCRS purpose correct?
If so remember it will never been checked/verified during judging.
Z06scentair is offline   Reply With Quote
Old 02-13-2015   #5
RICHARD TILL
I have a factory original AUAH chip for a 90. It was replaced by #16163905 due to the idle issue.
Old 02-13-2015   #6
I'm going to correct myself. You CAN use any LT-5 prom, however, since the 90 used an external Knock Sensor circuit, the 91-95 prom need to have the on board circuit removed.
Any 90 prom will work without modification. If u have a 90 prom, I can burn a new calibration for it.
