Old 12-08-2014   #1
Default Hydraulic flaring tool for fittings
Bought one of these to make fittings for plenum.....will see how they work
http://www.eastwood.com/universal-hy...ype={MatchType}
Old 12-08-2014   #2
Default Re: Hydraulic flaring tool for fittings
Looks like a neat tool..... and I like good tools. I will want to see pictures of the aluminum tube plenum connectors.
Old 12-09-2014   #3
looks pretty awesome: https://www.youtube.com/watch?v=ioeS-ymqtz0
Old 12-09-2014   #4
mike100
That thing is sweet. The next time I need to repair or make a hard line, I will by a quality hand-cranked tool, but that thing would make quick work of it and maybe flare the cleanest.
Old 12-10-2014   #5
Bought one of these to make fittings for plenum.....will see how they work.
http://www.eastwood.com/universal-hy...pe={MatchType}
Lee...that is a very nice TOOL and like Jerry said...We LIKE TOOLS
I especially like the Push Connect flare I think for the Plenum Fittings.
Let us know Fittings Sizes you use and what type of Tubing?
Eastwood.com Universal Hydraulic Flaring Kit
Buy Direct From Classic Tube
Universal Hydraulic Flaring Tool Kit
Oh...and that video is a great video
How To Use Classic Tube's Hydraulic Flaring Tool Set
Old 12-10-2014   #6
mike100
Oh! I didn't even notice that... This type of tool will go onto the wish list that I won't likely follow through on- like really high end tap and die sets and the like...
Old 12-10-2014   #7
Slick wonder how they would come out in stainless.
Old 12-10-2014   #8
I think they say you can't do stainless
Old 12-12-2014   #9
Well the hydraulic part of the tool turned out to be bad; I bought it used....but I was still able to make a few test runs on scrap aluminum tubing I had:
The quality was relative to how even the face of the tube was and the straightness....also you can vary the degree of the flare a lot
Old 12-14-2014   #10
That is the infamous Push Connect Flare used on the Plenum Fittings
Excellent Job Lee
If those fittings are the correct diameter, one can just use Red Loctite and push them into the Plenum where required if a fitting has become dislodged and lost or broken.
