My red 1990 Z has what looks like water spots on the hood and roof. Have compounded and waxed multiple times. Won't come out. Any suggestions?
Thanks in advance.
1990 ZR1 Red/Black #2469 1990 ZR1 Black/Black #843 1993 ZR1 Ruby 40th Anniversary #112 |
distilled vinegar and water 50/50 I think. lemme check
found it: 2. Try to dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following; a) Use a 2:1 or stronger solution of distilled water/distilled white vinegar (Acetic acid) b) Try a 2:1 solution of distilled water/Isopropyl Alcohol (adjust ratio as required) c) Or equal parts distilled water/distilled white vinegar/Isopropyl alcohol.
It's not the car, it's the people - Doug Johnson 90 r/r "KEYS ON" nick named "T.L.B" Last edited by Kevin; 06-21-2012 at 04:17 PM. |
Might have to color sand and buff out.
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
Start with the basics... clay.
If that doesn't work give Kevins vinegar mix a shot. If after those 2 you're still left with spots then you may have etching, which if severe enough may require a light sanding to correct, or at the very least some aggressive compounding.
[CENTER][B]USE COUPON CODE: [SIZE="3"][COLOR="Red"]ZR1[/COLOR][/SIZE] TO RECEIVE 10% OFF YOUR NEXT ORDER AT [url]www.ADAMSPOLISHES.com[/url][/B][/CENTER] |
Thanks guys. Will start with your suggestion Kevin and move on from there. Kevin any special way you apply?
1990 ZR1 Red/Black #2469 1990 ZR1 Black/Black #843 1993 ZR1 Ruby 40th Anniversary #112 Last edited by MickeyD; 06-22-2012 at 08:29 AM. |
i'd use a towel
Thread Tools | |
Display Modes | |
