Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > Cleaning and Waxing
Old 01-29-2012   #1
rhipsher
rhipsher's Avatar
Default First time Ive ever used a buffer.
Last year for christmas my wife got me a craftsman 10" duel action buffer and I just now opened it up and used it this evening with some Maguirs. Its unbelievable. Clear coat deep scratches are just gone.
Old 01-31-2012   #2
sammy
Default Re: First time Ive ever used a buffer.
great thing arent they , just one tip dont press down very hard you can go thru the clear in nothing flat . also use a glaze as you last compound and dont forget to put a coat of wax on when done .
Old 01-31-2012   #3
rhipsher
rhipsher's Avatar
Oh no Im just applying buffing compound with the applicator then let it sit a minute and buff it with the cotton buffing pad. Light pressure in circular motions one spot at a time. Not sure im doing it right but it looks way better than before.
Old 02-01-2012   #4
Dylan@Adams
Dylan@Adams's Avatar
Common misconception, and absolutely not true, especially with one of the low powered 10" bonnet style ones.
Really the only type of tool thats capable of removing enough material to go thru your clear is a rotary style high speed buffer.
Even the Porter Cable doesn't have the cutting power to go thru a clear coat and it oscillates more than 2x as fast as the tool hes using.
[CENTER][B]USE COUPON CODE: [SIZE="3"][COLOR="Red"]ZR1[/COLOR][/SIZE] TO RECEIVE 10% OFF YOUR NEXT ORDER AT [url]www.ADAMSPOLISHES.com[/url][/B][/CENTER]
Dylan@Adams is offline   Reply With Quote
Old 02-06-2012   #5
Socalerv
Tried to read this post three times and never got past the bouncing Betty.
Erv Myers
1990 ZR1 #1964
Socalerv is offline   Reply With Quote
Old 02-06-2012   #6
jimmy b.
jimmy b.'s Avatar
There was a post......
jimmy b. is offline   Reply With Quote
Old 02-07-2012   #7
Get dizzy when ever he post's.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 02-07-2012   #8
rhipsher
rhipsher's Avatar
I figured it could help wean you off the Viagra Frank. Lol!
