10-22-2015 | #31 | |
Re: Likely Heater Core Failure
https://www.rockauto.com/catalog/raf...ktemplate=true GATES 19743 {#11743, SID9743} Molded Heater Hose; 23/32" x 29/32" x 13" Category: Heater Hose / Pipe
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 10-22-2015 at 08:27 AM. |
10-22-2015 | #32 | |
I'm what I guess you could call a "RockAuto HATER" - I don't even use them for research. RA - NEVER!! |
10-28-2015 | #33 | |
In the mean time I found that the Heater Core Top Clip can be easily removed and re-installed after the New Heater Core is in Place. Remove the CDM before Removing or Installing the New Heater Core and Top Clip. The Installation is a lot simpler with the CDM removed. Without that Top Clip removed it might be almost impossible to re-install the Heater Core Tubes through the Fire Wall. Heater Core Top Clip. The Top Clip has a single 7mm head screw that can be removed once the Heater Core is removed. That screw and clip can be replaced once the New Heater Core is positioned reaching up under the hush panel with 1/4 inch socket wrench, 2 inch extension and 7mm socket. To replace the Heater Core without removing the Dash requires removal of the CDM. The Details are described in Item #2A Replacing the Heater Core and Heater Hose Connection |
08-30-2017 | #34 | |
Re: Removing Heater Core Without Pulling the Dash.
Thanks, John
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
08-31-2017 | #35 | |
Actually Cliff did the instruction I pulled the top of the Dash. I believe you can see the top of the blend door by simply pulling the glove box and shining a flashlight on the top of the air box.
Thread Tools | |
Display Modes | |
