02-12-2014 | #31 |
Re: Carter, new part,I think.
Up to temp and pressure, the fans just cycled. Good thing, my heater in the garage isn't keeping up with the door open.
Nice catch Cliff, aftermarket wires, they don't go in as far. Ask me about #8. -Steve |
02-12-2014 | #32 |
Still looks good, no creep or anything. Gotta shut her down, gettin' kinda light headed in the garage. Sorry about all the dirt in the picture, I just cleaned it up a little.
02-12-2014 | #33 |
Thanks efnfast for the leakage test and looks like we are good to go. Soon as I have the part number for the heat shrink I'll be able to research and give you guys a final price.
02-13-2014 | #34 |
Checked it again this morning, I did not start the car, just looked for creeping of the plug. None.
02-13-2014 | #35 | |
Gates Power Grip Clamps
I learned something here for sure....a very nifty way of installing a plug in a small hose where moderate water pressures are involved.....or use on radiator hoses That Gates Shrink Tube (Gates Power Grip Clamps) seems pretty tough stuff Gates Power Grip Clamps Looks like a Gates 465-32915 or 465-32919 or 465-32922 Gates Power Grip Clamp. I took my calipers out and yep .68 more or less as rubber is hard to measure. Now that is right on 11/16 inch so which Gates Power Grip do we use? The one that goes from 1/2 to 11/16 (465-32915) or the one that goes from 11/16 to 13/16 (465-32919)? The first one might not fit on the hose and the last one might be too lose You can also find them on Ebay...for 1/4 inch hose, 3/8 inch hose, or 1/2 inch hose......and larger. Gates 465-32915 Power Grip Clamp Gates 465-32919 Power Grip Clamp Gates 465-32922 Power Grip Clamp
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-13-2014 at 01:18 PM. |
02-13-2014 | #36 |
Cliff, if memory serves, 11/16th od. Not 100% sure of that.
Those appear to be the clamps. Used an electric heat gun, I think the last time I used a propane torch. I recommend the heat gun. |
02-13-2014 | #37 | |
Is there a part number on your Gates Power Grip Clamp....I am guessing it is 32919??? I took my calipers out and yep .68 more or less as rubber is hard to measure. Now that is right on 11/16 inch so which Gates Power Grip do we use? The one that goes from 1/2 to 11/16 (465-32915) or the one that goes from 11/16 to 13/16 (465-32919)? The first one might not fit on the hose and the last one might be too lose As I recall...flyin ryan used these Gates Power Grip Clamps on Radiator Hoses.....but it did not sink in back then as to the smooth look and effectiveness of these clamps on Radiator Hoses I will now try to find that flyin ryan post.....could not find flyin ryan post but here is another post on using Gates Power Grip Clamps for radiator hoses. Gates Power Grip Clamps used as Coolant System Hose Clamps
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 02-13-2014 at 01:30 PM. |
02-13-2014 | #38 |
Pricing for Bypass Plug
The Bypass Plug pricing is as follows:
Bypass Plug - $20 shipped Bypass plug with Heat shrink hose clamp - $25 shipped Bypass Plug engraving is additional $8 - $10 (depending on engraving) PM or email me for payment info. Thanks and appreciate you support, Carter200 (CT Machining)
02-13-2014 | #39 |
Thanks Carter, I can't express enough how much better this plug looks than anything else I've seen. (No, I am not a paid spokesman, I just play one on tv).
02-13-2014 | #40 | |
Thanks for your assistance on this project. I really like it and hope many others will to. Stay warm, Carter
Thread Tools | |
Display Modes | |
