09-17-2024 | #21 |
Re: A/C blower fan won?t turn off
I've been fighting this same problem for a few months.
Recently I noticed my wiring harness is the same as yours pictured Starman with 3&1 contacts as opposed to the 4 & 2 contacts on the BCM. I have a Jeep unit ordered and am crossing my fingers that it works. |
10-16-2024 | #22 | |
Thanks.
1968 convertible Lemans Blue, 1986 coupe Medium Blue NCRS Top Flight (sold), 1990 ZR1 #2529 Red NCRS Regional and National Top Flight (sold), 1990 ZR1 #2124 Charcoal Metallic NCRS Top Flight 2010 & 2018, 2003 Anniversary Red Convertible (sold) |
10-16-2024 | #23 |
I purchased mine through eBay. This was the link. The unit worked fine but it did need minor modification. I had to swap my cooling fins on the OE part with the replacement. The replacement fins were too large to fit the opening. The plugs matched up perfectly and it has not been a problem since. If you do this swap, be sure to try and retain as much of the adhesive. It is also a heat dissipative as I understand it. https://www.ebay.com/itm/15580780457...mis&media=COPY
It was a relatively easy swap. |
10-16-2024 | #24 |
I purchased the Jeep module off of Amazon and it works. Mine fit with no modifications. The holes didn't line up exactly, but that's not a big deal.
Here's the title: 4720046 4P1721 Blower Motor Resistor ATC Control Module Replacement for Jeep Grand Cherokee 1993-1996 Part# RU-759 16173860 53-69657 GELUOXI |
10-16-2024 | #25 | |
Thread Tools | |
Display Modes | |
